How do I fix my uneven oil pan
stravi757
My oil pan is very uneven causing me to lose a lot of oil because of a bad seal. The oil pan had been screwed in to tightly leaving the oil pan surface very uneven. Any advise for how I should go about making the surface flat again?
You really won't get it truly flat again. The best you can do is get a ball perm hammer and some to place on the back side of the hole. Hammer lightly to flatten the lip around the hole
Repeat for all deformed holes. Reassemble the pan and put black RTV on the pan side of the gasket.
