badspeed2 Posted April 15, 2010 Share Posted April 15, 2010 (edited) Hey all, About to start putting Chevy V8 engines into a white '87 300ZX Turbo with automatic. First up is an LS1 with a matching GM 4L60e auto trans. I'll start with pics of installation, then the clearances. Once I've designed mounts for that, and done more pics, it'll be removed, and an older 350 engine installed, more pics, more mounts, then more pics. If at the end you like what you see, I'll be offering all the measurements for making your own mounts, and I'll offer my design ready to install. Enjoy the show! Edited April 15, 2010 by badspeed2 Quote Link to comment Share on other sites More sharing options...
zman6988 Posted April 24, 2010 Share Posted April 24, 2010 Yes defin. interested I'm swapping a 95 LT1 with 4L60E out of a Z-28 into my 86 300zx. PLEASE KEEP ME POSTED ON YOUR STATUS. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted May 13, 2010 Share Posted May 13, 2010 i would be interested in ls1 mounts too. let me know Quote Link to comment Share on other sites More sharing options...
badspeed2 Posted July 13, 2010 Author Share Posted July 13, 2010 i would be interested in ls1 mounts too. let me know I've been unable to log on for a while. My progress is slower than anticipated, there are already a few other guys doing this swap, who are telling about it on www.ls1tech.com So far, noone is offering mounts or anything, and so far, noone is even commenting on which headers or exhaust manifolds, and which oilpan. I'm trying to get my hands on a used '98-'02 Z28/TransAm LS1 pan, because new ones are $170. Using this pan may require notching the crossmember, or a bit of hammering on the firewall, or both. AutoKraft makes a pan that's rumored to fit, but it's $400, and might interfere with fitting an exhaust system. The H3-Alpha oilpan would be an easy fit, but like the truck pan, would hang too low. I'm also trying to get an '05-'06 'vette Ls2 pan for my LSx Fiero, but if I can get one, I'll also try it in here. I have a lead on a T5 from a '92 Z28, and admittedly it's not very strong, but it is small and light, and places like Astro Perf. and G-Force can make it strong enough for 500 ft-lbs input torque. The best alternative is the Tremec TKO600, but that runs around $1900 new. A used '88-up T5 with a kit is cheaper, lighter and smaller. Plus Nissan installed some T5s in some Z31s, so mounting and connecting the T5 should be easier. It may be possible to use certain stock driveshafts, while the tkO600 requires a different yoke on the front of the driveshaft. Sorry no helpful pics yet. Quote Link to comment Share on other sites More sharing options...
badspeed2 Posted September 18, 2010 Author Share Posted September 18, 2010 I've been in the hospital for way too long, but I'm out now. I've had friends working on the '85 300ZX for me as a surprise gift, and it was touching. They've replaced the rear springs and shocks, primarily. The work looks good. Those springs will help me get the legs of a cherry picker under the car without hitting anything. Speaking of which, someone has donated a Chevy 350 block for my test-fitting, too. Everyone smiles, but noone's telling who. Still, there it sits. I'll get pics this afternoon, if at all possible. Quote Link to comment Share on other sites More sharing options...
badspeed2 Posted September 21, 2010 Author Share Posted September 21, 2010 I just re-read everything I've typed so far. Before I start adding pics, I need to clarify. Use of the '87 was revoked, so I got my own '85. It was in bad shape. Anyway, here are the promised pics: Quote Link to comment Share on other sites More sharing options...
andre493 Posted September 21, 2010 Share Posted September 21, 2010 What happened to the springs. Quote Link to comment Share on other sites More sharing options...
badspeed2 Posted September 22, 2010 Author Share Posted September 22, 2010 The one on your left in the pic was on the passenger side. The bottom coil was broken. The other was torched to match. You should've seen the front springs. Torched until useless, the front was riding on the bump stops. Anyway, I'm frustrated that I have not found opportunity to pull the V6 and get going on the V8. I have the 350, and I have the LS1, plus an empty 4L60E case, all sitting ready for test-fitting. Quote Link to comment Share on other sites More sharing options...
Calico Posted October 5, 2010 Share Posted October 5, 2010 I'm def interested in this. Quote Link to comment Share on other sites More sharing options...
nphocus Posted October 9, 2010 Share Posted October 9, 2010 I'm interested too. I have an 88T with stuck piston rings. I bought a 94 firebird formula with an LT4 and T56 JUST to get the drivetrain to go into my 300zx. I would love to buy a kit to make this happen or to find a builder in Virginia that specializes in these kinds of swaps. I do remember seeing a v8 300zx making passes at the local dragstrip a while ago. Unfortunately I was running my mustang at the time and not really paying much attention to it outside of noting it was pretty neat. Subscribed. Quote Link to comment Share on other sites More sharing options...
newatz Posted August 19, 2011 Share Posted August 19, 2011 If some make a kit I will buy I have a 1984 300Z I what a V8 kit Quote Link to comment Share on other sites More sharing options...
260DET Posted September 8, 2011 Share Posted September 8, 2011 So what happened here. Quote Link to comment Share on other sites More sharing options...
Calico Posted December 8, 2012 Share Posted December 8, 2012 funny cause when i mentioned putting lt1s in z31s over on z32performance they cried that no one would want it. yet here it is. keep up the great work, i think this is awesome. Quote Link to comment Share on other sites More sharing options...
