xonix_digital Posted April 20, 2010 Share Posted April 20, 2010 Just took my car out for my weekend cruise and realized my directional signals are working erratically. If I turn them on sometimes they don't go, sometimes the click a few times and then stop for a while, and start back up. Sometimes they work right away. They are working the same for both directions. Are there any directional diagnostic threads? Do any of you guys have any ideas of what to check first? Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted April 20, 2010 Share Posted April 20, 2010 The first, and easiest, thing I'd check first would be grounds. Take off all the ground connections related to the lights and make sure you have a good clean connection. That could well be the issue. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
xonix_digital Posted April 20, 2010 Author Share Posted April 20, 2010 I will test and check that. Thanks! Quote Link to comment Share on other sites More sharing options...
TheMission Posted April 20, 2010 Share Posted April 20, 2010 Your "Flasher" could be going out as well... Heck, it's lasted quite a long time if it's original. The stock wiring of the signals is a bit of a pain, but it's not too complicated (get's a little weird with the hazard switch involved, but they ground out near each light, so if your having the issue both left and right, it leans me away from grounds. If it's the same both directions, I'd say it's more likely to be a flasher/switch issue. Quote Link to comment Share on other sites More sharing options...
xonix_digital Posted April 21, 2010 Author Share Posted April 21, 2010 The hazard switch! Do the hazards use a separate switch? Or does the blinker switch wiring run into the hazard switch? Quote Link to comment Share on other sites More sharing options...
TheMission Posted April 21, 2010 Share Posted April 21, 2010 On my '72, the front and rear turn signal light powers go through the hazard switch before they hit the turn signal switch, when hazards are turned on, the power goes through the hazard switch to the lights and negates the turn signal switch. When you have problems with your signals and turn the hazard switch on, does that work properly? Quote Link to comment Share on other sites More sharing options...
xonix_digital Posted April 21, 2010 Author Share Posted April 21, 2010 I will let you know tonight. Thanks! I never thought of that. Quote Link to comment Share on other sites More sharing options...
xonix_digital Posted April 26, 2010 Author Share Posted April 26, 2010 So it turns out my Signal relay was full of water. The electrical contacts were rusty. It took John from ZCCNE (Z Car Club of New England) about 5 seconds to figure it out at the Annual charity tech-inspection this past weekend. So Thanks go out to him for the fix and you guys for the insight. - Alex Quote Link to comment Share on other sites More sharing options...
catalak Posted April 10, 2012 Share Posted April 10, 2012 So it turns out my Signal relay was full of water. The electrical contacts were rusty. It took John from ZCCNE (Z Car Club of New England) about 5 seconds to figure it out at the Annual charity tech-inspection this past weekend. So Thanks go out to him for the fix and you guys for the insight. - Alex Alex, Any pix of the turn signal relay? I'm having the exact same problem... Except on Sunday, mine finally died out o_o thanks!! Quote Link to comment Share on other sites More sharing options...
nacitar Posted August 8, 2012 Share Posted August 8, 2012 My signals work properly but after turning they don't cancel/reset; not sure how I'd go about fixing that. Quote Link to comment Share on other sites More sharing options...
