Stub Axle/Companion Flange Copper Washer
jacob80
Hey guys,
Well I have come across the copper washers that fit somewhere within the stub axle assembly. I've read that it reduces the metallic scraping sound or something of the sort in later 240z's. My question is:
I have modern motorsports CV adapters, but where will this copper washer install? Does it go in the order:
Lock Nut>Washer>Adapter/Companion flange>Copper washer?
Does the copper washer fit over the spines of the stub axle? Thanks!!
Guys,
I read that the copper washer is used to prevent the metallic grinding sound in later 240z's. However, I installed 280z 27 spline stub axles, and the copper washer would not fit over the splines. I installed the stub axles without, and the sound isn't going to bother me, just as long as no potential damage is done.
