Need Help I.D.ing a part for vacum
motoman
I would think it would raise boost from the wastegate setting of 5 to about 7 when the car gets into operating temp. Cant really see how a device on the wastegate line could actually LOWER past what the wastegate is set for. Either way I would ditch it and run a boost controller lol
Yes, it's the stock 2 step boost solenoid. It regulates the boost, 5 psi up to 4500rpm. Then bleeds of air, allowing the boost to be raised to 7psi on rpms above 4500... Remove it and you'll be runnin constant 5 psi (if you don't get a boost controller that is), or if you connect a permanent ground to it, then you'll run permanent 7psi (no longer 2 step). Linked is a nice write up about this thing:-)
http://www.skylinesaustralia.com/forums/HOWTO-RB25DET-High-Boost-t42895.html
Edited by 240zrb
