Two80z4me Posted June 16, 2010 Share Posted June 16, 2010 hey, I looked this up and I couldnt find anywere. which way does the pump pull fuel? right now I have it hooked up like so.. -[][][][](pos/neg)- and on the outlet by the pos/neg posts I have it coming from the fuel tank and the opposite side of the pump going to the Injectors, but my problem Is I dont think thats right and I think its pulling fuel from the fuel rail to the tank, which is useless lol. if anyone has the chart or knows if I have it set up backward, please do tell Quote Link to comment Share on other sites More sharing options...
Snailed Posted June 16, 2010 Share Posted June 16, 2010 The side with the terminals is the outlet. Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted June 16, 2010 Share Posted June 16, 2010 That is how mine is plumbed: Make sure the polarity of your wires is right - if they are backwards the pump will pump backwards. Quote Link to comment Share on other sites More sharing options...
Nigel Posted June 17, 2010 Share Posted June 17, 2010 Isn't there a big arrow stamped into the side of the housing with the word "Flow" printed in it. I'm pretty sure that's what's on mine... Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted June 17, 2010 Author Share Posted June 17, 2010 Isn't there a big arrow stamped into the side of the housing with the word "Flow" printed in it. I'm pretty sure that's what's on mine... Nigel '73 240ZT someone glued the cover onto mine, so I cant read it or get the cover off. so the side with the terminals is the outlet for the fuel rail? if so Ill just wire mine backward Quote Link to comment Share on other sites More sharing options...
motoman Posted June 17, 2010 Share Posted June 17, 2010 Yes the side with the terminals is the outlit. I would suggest just turning the pump around it most likely designed to flow in a certain direction. Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted June 17, 2010 Share Posted June 17, 2010 if so Ill just wire mine backward Do it right!! "FLOW -->" [pointing towards the terminals] Quote Link to comment Share on other sites More sharing options...
Nigel Posted June 17, 2010 Share Posted June 17, 2010 Do it right!! "FLOW -->" [pointing towards the terminals] Agreed! Regardless, the check valve in the outlet will prevent it from flowing backwards anyway... Nigel Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted June 18, 2010 Author Share Posted June 18, 2010 lol I fixed it and did it the right way, no im not getting power to the pump, so im going to do it on a seperate relay with a switch. good ole switches Quote Link to comment Share on other sites More sharing options...
motoman Posted June 18, 2010 Share Posted June 18, 2010 Don't forget to wire in an oil pressure switch incase you do have one of those crazy things happen and the pump just keeps pumping. That wouldn't be to fun to have happen. Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted June 18, 2010 Author Share Posted June 18, 2010 I dont think I need to wire one in, but I think your right. back to the auto parts store for more supplies. Quote Link to comment Share on other sites More sharing options...
