ciavola Posted June 27, 2010 Share Posted June 27, 2010 I need to replace this baffle, anyone have an idea on where to get one? or what to use in place of one? from a 71 240z Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 27, 2010 Share Posted June 27, 2010 I need to replace this baffle, anyone have an idea on where to get one? or what to use in place of one? from a 71 240z Sorry, can't offer info on finding a new one, but I can tell you that I have cleaned up ones worse than that one before and re used it. Get yourself a propane torch and cook all that crude to a crisp, then get you a flat scrapper and get between each screen are and scrape it till the cooked dust falls out. A air hose helps this quite a bit.... Quote Link to comment Share on other sites More sharing options...
ciavola Posted June 27, 2010 Author Share Posted June 27, 2010 This thing is falling apart, rusted through in spots. Quote Link to comment Share on other sites More sharing options...
ciavola Posted June 27, 2010 Author Share Posted June 27, 2010 I tried it anyway with the torch, it literally fell apart. it appears to be the same a metal window screen? Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 27, 2010 Share Posted June 27, 2010 most windowscreen these days is nylon. You can get stainless mesh from McMaster-Carr supply, it's a lifetime replacment if it's SS. Quote Link to comment Share on other sites More sharing options...
jasper Posted June 27, 2010 Share Posted June 27, 2010 http://www.amazon.com/Brass-Mesh-014-Wire-Diameter/dp/B001CTWYMA Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 27, 2010 Share Posted June 27, 2010 http://www.amazon.co...r/dp/B001CTWYMA Thai is a better solution than mine.... Quote Link to comment Share on other sites More sharing options...
ciavola Posted June 28, 2010 Author Share Posted June 28, 2010 Thanks for the replys, I'll try the brass. Quote Link to comment Share on other sites More sharing options...
ciavola Posted July 4, 2010 Author Share Posted July 4, 2010 I found one through the dealer, and for 8 dollars. thaks for the suggestions though. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted July 7, 2010 Share Posted July 7, 2010 the screens available at home depot are: fiberglass, vinyl coated nylon or aluminum. I would not recommend any of them for your application lol. Quote Link to comment Share on other sites More sharing options...
Oddmanout84 Posted March 20, 2011 Share Posted March 20, 2011 Soak it in carb cleaner for a day or two, then wash it out. Autozone sells gallon buckets of the stuff, with a nifty drop basket inside so you don't have to dig your parts out from the bottom of the can with your hands. Quote Link to comment Share on other sites More sharing options...
z-ya Posted March 28, 2011 Share Posted March 28, 2011 I found one through the dealer, and for 8 dollars. thaks for the suggestions though. Exactly my suggestion. Why is it people don't try Nissan for for a stock item? Quote Link to comment Share on other sites More sharing options...
