Air Regulator / Idle Question
240Z_Master
  • 13 years later...
Yes old-post but for those searching the forums,
similar issues with series 1 RB 25 DET with stock intake and stock ECU in a 73 Datsun 240z.
my solution
Air regulator power does not come from ECU , raises idle when cold , not ECU controlled .
Chris's guide does cover it .
Air regulator valve needs 12v , connects to 6 pin grey connector next to water temp sensor , wire color light blue  the aqua wires are for knock sensor's
my wire in was found under intake close to wire for knock sensor . ( was not connected, i suppose in Ca was not essential - but car ran poorly on start up )
hope this helps someone, ,
