z32 shortnose vlsd swap into s130
bluezx
Started to post this in the drivetrain section but I'm looking for info on this swap in an S130 not S30.
I've had no luck finding a direct bolt-in long nose R200 lsd diff. to install in my car.
So, I got a good deal on a 1991 300zx nonturbo short nose vlsd R200 diff. and axles.
Having researched this topic I've found all the info I need to install this vlsd carrier into my R200 longnose case using 10mm to 12mm spacers to retain my ring and pinion gear with the 3.54 ratio my turbo likes.
My issue now is sorting out what combo of cv axles and parts (stock and or custom) it's going to take to complete this install with a minimum of fabrication.
I can get any parts off a few S13's,J30's,early z31's(84-85 turbo and non),and a Q45 at my friends junkyard.
I understand this is not going to be a direct bolt-in affair and have no problem drawing and having adapters machined with pics and write-up to help other S130 owners accomplish this.
Any comments or advice?
Thanks for the feedback guy's.
Pure Pontiac,
I haven't installed the lsd yet and do plan to shim it. Were's a good place to get shims?
I found the thread on Z31 performance and it was very helpful,thanks.
260DET, Not sure I understand your warning about the pinion. I'm only using the vlsd from the shortnose diff. The long nose case will keep it's original ring and pinion gears.
So, unless I've missed something the main issue to resolve is what hybrid axle combo it's going to take to connect the output flanges of the diff to my stub axles correctly.
My plan is to try to install the inner cv joints from the Z32 axles onto my s130 axles and test fit to see if they'll work or need to be modified.
