tech9 Posted September 13, 2010 Share Posted September 13, 2010 I have a stock hy35 that i'm getting setup. I have seen a lot of people modify theirs for a vband setup and mine is just a bolt on normal holset flange that goes to the stock dodge downpipe, which I do have but I would like to stay away from. Can I modify this turbo to make a vband seal on the exhaust to downpipe? Or do I need to just create a downpipe with a holset flange (they sell these on ebay all day)? A little confused on how these holsets are, maybe some have vband and some don't? Thanks! Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted September 14, 2010 Share Posted September 14, 2010 Holset HX35, HY35, and WH1C turbos all have a "bolted" connection outlet to the turbo. All of the other "reasonable" Holset turbos (like the HE351) have some kind of v-band connection that isn't a 'normal' size V-band flange... it is some kind of in-between Holset metric wierd-ass size that no vendor (that I could find) sells an adapter and vband clamp for. You are pretty much stuck with modifying the stock elbow (which I've seen done on this site by 2 different people), or cut off the v-band altogether and weld on a standard 4" flange (like I did). You have a bolt on flange... buy a mild steel flange off of ebay, bolt it to your turbo and run a 3" exhaust tube right off the back of that thing for your downpipe. A tube through a flat plate weld has pretty much the very worst fatigue characteristics of any weld joint so I would make sure to put in a flex connection somehwere before you support the exhaust / downpipe to the car. A gusset or 2 from the flat plate to the tube would be good insurance against a weld crack as well. Quote Link to comment Share on other sites More sharing options...
LamboZ Posted September 18, 2010 Share Posted September 18, 2010 the apt turbo 4in vband setup worked just fine on my hy35w. using stock 4in vband off turbo. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted June 1, 2011 Share Posted June 1, 2011 (edited) I'm reviving this dead thread because I want to ask someone that knows a little more about this topic. I also have an HY35 and will be going external, will this work to close up the internal wastegate portion?: http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-FLS-036&Category_Code=FLG ...and then weld on one of these bad boys for the perfect setup: http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-FLS-041&Category_Code=FLG and THENNNN slap on one of these bad boys: http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-MDP-011&Category_Code=BCS Edited June 1, 2011 by jacob80 Quote Link to comment Share on other sites More sharing options...
frankist Posted June 1, 2011 Share Posted June 1, 2011 you can use that, it wont close it up though, your going to need to weld the flapper shut, i just welded the arm outside the turbo, its worked since, i wouldnt recommend welding the flapper inside. Quote Link to comment Share on other sites More sharing options...
frankist Posted June 1, 2011 Share Posted June 1, 2011 let me know if you need a picture of what i did. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted June 1, 2011 Share Posted June 1, 2011 that 3 to 4" downpipe is overpriced. plus the angle is not the best. I had an exhaust shop make me a downpipe that went from 2.5-3" with two 45 degree bends, 2 bungs, and a Vband clamp on both ends for $100 Quote Link to comment Share on other sites More sharing options...
jacob80 Posted June 1, 2011 Share Posted June 1, 2011 (edited) that 3 to 4" downpipe is overpriced. plus the angle is not the best. I had an exhaust shop make me a downpipe that went from 2.5-3" with two 45 degree bends, 2 bungs, and a Vband clamp on both ends for $100 That is a great price, good work! As for the pricey downpipe, I believe it justifies ATP's quality of work. All of their stuff looks to be of very good quality. Edited June 1, 2011 by jacob80 Quote Link to comment Share on other sites More sharing options...
