Elemeno Posted September 22, 2010 Share Posted September 22, 2010 I have no idea how it happened but the needle doesn't move anymore. Anyone have any idea of how to fix it? Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted September 22, 2010 Share Posted September 22, 2010 Check the connection of the speedometer cable into the back of the speedometer and also check the connection to the transmission. Do some searching about it and you should find some more details you should also down the FSM from xenons30.com or xenons130.com depending on which vehicle you have. Quote Link to comment Share on other sites More sharing options...
Elemeno Posted September 22, 2010 Author Share Posted September 22, 2010 kk I'll look into it. Have the FSM but it confuses me >.< Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted September 22, 2010 Share Posted September 22, 2010 kk I'll look into it. Have the FSM but it confuses me >.< When you have the time just go through the whole thing, some of the pictures will be helpful but otherwise just take some time to understand it I usually read through it every once in a while, I learn new things and it has helped me plenty of times. Quote Link to comment Share on other sites More sharing options...
ktm Posted September 23, 2010 Share Posted September 23, 2010 Year of car would help tremendously. Quote Link to comment Share on other sites More sharing options...
Elemeno Posted September 23, 2010 Author Share Posted September 23, 2010 (edited) 1981 280zx Edited September 23, 2010 by Elemeno Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted September 23, 2010 Share Posted September 23, 2010 1981 280zx Well in that case my information might be worthless haha I have no idea if the 280zx is the same as earlier Z's when it comes to speedometer cables. Quote Link to comment Share on other sites More sharing options...
jhm Posted September 23, 2010 Share Posted September 23, 2010 Most likely a broken speedo cable (not the cable housing, but the thin piano wire-like cable that runs internal to the thick black cable housing). You can usually find generic speedo cable repair kits at most auto stores for a few bucks. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted September 23, 2010 Share Posted September 23, 2010 pull the drive cable out of the sheath to be sure it isn't broken. if it is whole then be sure the connections are tight. to test the speedo itself you need to pull the module out that houses the speedo and other gages. an electic drill with a match stick in it is usually sufficient to drive the speedo to be sure it is working. but your problem is most likely to be poor connection broken cable. Quote Link to comment Share on other sites More sharing options...
