zrookie Posted October 6, 2010 Share Posted October 6, 2010 This is mostly for documentation or to serve to someone as an example. I let you know what I come out with. So today I just went to fire up my car for a run, and started fine and then just died. tried to crank it again and it start but die within 10 seconds. I checked and there is no spark, so that narrows the problem down. I thinking is faulty relay, but I need to do some testing first. I also noticed that when I moved the cas looking to advance or retard the timing the fuel system would kick in. Today it started to rain, but tomorrow I would do the necessary testing to my baby. any advice or comments are welcome. Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 7, 2010 Author Share Posted October 7, 2010 Rainy day. couldn't do anything. Quote Link to comment Share on other sites More sharing options...
stony Posted October 7, 2010 Share Posted October 7, 2010 Rainy day. couldn't do anything. Had the same issues with mine a long time ago. it was a bad ground. Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 7, 2010 Author Share Posted October 7, 2010 Had the same issues with mine a long time ago. it was a bad ground. I thought about that also and I checked the coil pack ground, but nothing, Which ground did you had an issue with? Thank you for letting me know, I would check all my grounds and clean them up. Hopefully tomorrow and jump on it. I just put the whole thing back together with new cams and it sounded gorgeous for that minute...lol again thank you Stony. Quote Link to comment Share on other sites More sharing options...
stony Posted October 7, 2010 Share Posted October 7, 2010 The ground from the ECU to chassis ground. took it off cleaned to bare metal and reconnected... didn't have another issue. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted October 8, 2010 Share Posted October 8, 2010 Also maybe check the ground at your CAS... since you seem to rotate it.. then it kicks on and off... could be a problem (also make sure you reset your ECU per the FSM)... after a couple fault codes the ECU likes to operate in safe mode.... which is very boring! Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 8, 2010 Author Share Posted October 8, 2010 Also maybe check the ground at your CAS... since you seem to rotate it.. then it kicks on and off... could be a problem (also make sure you reset your ECU per the FSM)... after a couple fault codes the ECU likes to operate in safe mode.... which is very boring! Stony thanks a lot brother, Q the fuel pump seems to kick in, like getting the system ready to turn on. I would follow your advice also. thank you. I need some time to work on it, WHY AM I SO BZ THIS WEEK!!!!???? Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted October 8, 2010 Share Posted October 8, 2010 Stony thanks a lot brother, Q the fuel pump seems to kick in, like getting the system ready to turn on. I would follow your advice also. thank you. I need some time to work on it, WHY AM I SO BZ THIS WEEK!!!!???? Does your fuel pump seem to be on all the time like it's supposed to? Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 8, 2010 Author Share Posted October 8, 2010 Does your fuel pump seem to be on all the time like it's supposed to? yes sir,the problem is just the sparkless motor, That's why you can hear the pump kick in. and to think I just put my motor apart to do some head work (two bended valve and bad seals) and cams and now look... NOOOOOOO!!!! Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted October 8, 2010 Share Posted October 8, 2010 yes sir,the problem is just the sparkless motor, That's why you can hear the pump kick in. and to think I just put my motor apart to do some head work (two bended valve and bad seals) and cams and now look... NOOOOOOO!!!! Check the 6/7 wires going to and from the igniter on both sides... check and recheck wires... most importantly hook that bad boy up to a Nissan Consult program of some sort and diagnose error codes... I can't read the blinking read light on the ECU so don't even ask me about that Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 8, 2010 Author Share Posted October 8, 2010 Check the 6/7 wires going to and from the igniter on both sides... check and recheck wires... most importantly hook that bad boy up to a Nissan Consult program of some sort and diagnose error codes... I can't read the blinking read light on the ECU so don't even ask me about that you definitely got ahead of me on this one, I tried my consult to check what you mention in regards to the ECU running safe mode, but now the consult (ECUTALK) is no conecting to my labtop... the seller mentioned to check my installation for power and Grnd, everything is good. so later on today I would spend some quality time with my baby... I wanna drive it to the meet in torrance tonight. I hate procrastination... I would check the 6/7 wires also... thank you brother. Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 11, 2010 Author Share Posted October 11, 2010 (edited) So afer troubleshooting for half a hour, everything tested good. when I took the for testing this is what I found, weird, yes I know. The new tomei exhaust cam does not hook onto the cas, I wonder if the cam is for a NEO RB. here is the pic. I have to call the seller tomorrow, I'm so pissed off... all this work to find out that I have to do it again. BTW thank you all for all the suggestions, it help me a lot. the old rb25det cam the Tomei cam installed Edited October 11, 2010 by zrookie Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted October 11, 2010 Share Posted October 11, 2010 So afer troubleshooting for half a hour, everything tested good. when I took the for testing this is what I found, weird, yes I know. The new tomei intake cam does not hook onto the cas, I wonder if the cam is for a NEO RB. here is the pic. I have to call the seller tomorrow, I'm so pissed off... all this work to find out that I have to do it again. BTW thank you all for all the suggestions, it help me a lot. the old rb25det cam the Tomei cam installed Correct me if I'm wrong but doesn't the CAS go on the exhaust cam? Quote Link to comment Share on other sites More sharing options...
stony Posted October 11, 2010 Share Posted October 11, 2010 Oh man you didn't get the cams mixed up did you? i do believe they will interchange Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 11, 2010 Author Share Posted October 11, 2010 Correct me if I'm wrong but doesn't the CAS go on the exhaust cam? WHAT!!! did I say intake...lol... I meant exhaust. sorry man, have you seen this before? Quote Link to comment Share on other sites More sharing options...
stony Posted October 11, 2010 Share Posted October 11, 2010 just out of curiosity look at the intake cam and make sure you didn't swap them Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 11, 2010 Author Share Posted October 11, 2010 Oh man you didn't get the cams mixed up did you? i do believe they will interchange I thought I did at first, but then I realized that the intake has a center bolt and a notch in the outer section, the exhaust have four bolts and the CAS connecting gear in the center, which I took pictures of. they are identical bu different. BTW I just called frsport.com, and we came to the conclusion that I have the series 2 exhaust cam, just a simple mistake, lol... There is actually a note in the box from Tomei stating the CAS difference. The funny thing is that the guy knew I needed a series 1, we talked about it and it was crystal clear, but i guess he grabbed the wrong box and I was too exited to even check... they are going to order the cam for me and I just have to return it. THIS GUYS ARE AWESOME!!! Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted October 11, 2010 Share Posted October 11, 2010 I thought I did at first, but then I realized that the intake has a center bolt and a notch in the outer section, the exhaust have four bolts and the CAS connecting gear in the center, which I took pictures of. they are identical bu different. BTW I just called frsport.com, and we came to the conclusion that I have the series 2 exhaust cam, just a simple mistake, lol... There is actually a note in the box from Tomei stating the CAS difference. The funny thing is that the guy knew I needed a series 1, we talked about it and it was crystal clear, but i guess he grabbed the wrong box and I was too exited to even check... they are going to order the cam for me and I just have to return it. THIS GUYS ARE AWESOME!!! IF IT AINT BROKE DONT FIX IT! Quote Link to comment Share on other sites More sharing options...
zrookie Posted October 12, 2010 Author Share Posted October 12, 2010 IF IT AINT BROKE DONT FIX IT! Oh no my friend, it was definitely broke, I told you about it @ in and out, three bent valves, gone valve seals, and a broken intake cam, leaking oil from the cam seals, timing belt was off place and it went bad also, 3 leaky injectors, and of course burning too hot... a pure mess.....so yeah.... mayor work baby... and it came out gorgeous. I'm so ready for a get together Q. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted October 12, 2010 Share Posted October 12, 2010 Oh no my friend, it was definitely broke, I told you about it @ in and out, three bent valves, gone valve seals, and a broken intake cam, leaking oil from the cam seals, timing belt was off place and it went bad also, 3 leaky injectors, and of course burning too hot... a pure mess.....so yeah.... mayor work baby... and it came out gorgeous. I'm so ready for a get together Q. FAIL! LOL Quote Link to comment Share on other sites More sharing options...
