TomoHawk Posted August 20, 2002 Share Posted August 20, 2002 The spring that holds the door in position is mising on my 280Z. Can you substitute something in there, or do I need an original spring? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 20, 2002 Share Posted August 20, 2002 Another spring from a similar year datsun may work. The original door spring had a tension for that particular door weight application and to operate correctly may require an original type spring. A lot of the old 70 model Datsun cars and pick ups without periodic lubrication had spring and hinge pin problems that were ripping the door hinges loose from the door wells. Quote Link to comment Share on other sites More sharing options...
Sleek Z Posted August 21, 2002 Share Posted August 21, 2002 TomoHawk You might consider investing in an inexpensive ($10) parts interchange guide such as I sell at http://www.zparts.com/literature/icminfo.html It will serve you for many years past the point of just using it to find the correct hinge for your car. It will show you clearly that Nissan used 3 different upper and 2 different door hinges on 70-78 Z cars. Try to install the wrong one from the wrong production date and most likely your door will not close or latch properly, but I do not know that for certain. btw, I propably have door hinges from all 70-78 models as well if you can't find the correct one in your area. . Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted March 12, 2007 Share Posted March 12, 2007 My door hinges may need some help. On the lower hinges (the ones with the spring) the little round cylinder shaped piece of metal that the spring arm travels on is deeply grooved with some indents. These cause the door to sometimes pop when opening and closing the door. I assume these little pieces used to be round and the indentations are causing the "pop". Can these pieces be sourced to refurbish the hinges? Thanks. Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted March 12, 2007 Share Posted March 12, 2007 This thread has some part numbers in it, not sure if you are looking for these, it might help: http://forums.hybridz.org/showthread.php?t=117283 Quote Link to comment Share on other sites More sharing options...
CalifaThugz Posted March 13, 2007 Share Posted March 13, 2007 Hey when I was taking the fender off of my 280z I unbolted the fender and a damn spring flew off and hit my ear... now I can't find it... Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted March 13, 2007 Share Posted March 13, 2007 Sparks280zt said: This thread has some part numbers in it, not sure if you are looking for these, it might help: http://forums.hybridz.org/showthread.php?t=117283 Thank you! Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted March 14, 2007 Share Posted March 14, 2007 I just got the link with the writeup on rebuilding hinges to work and those are not the parts I need. I need the roller on the lower hinge that the spring arm rides on. Mine are very worn and the spring arm "pops" as it rides over them when opening and closing the door. Any ideas? Quote Link to comment Share on other sites More sharing options...
DaleMX Posted March 14, 2007 Share Posted March 14, 2007 Mine was popping for a while then suddenly "Wham!" the spring went flying. The door opens and closes smoothly now (HA!). In fact the resistance is so low that it feels like a Lexus door. Too bad it wont stay open on it's own any more. Quote Link to comment Share on other sites More sharing options...
