Zfan1 Posted October 29, 2010 Share Posted October 29, 2010 I was thinking of swapping out the 3.70 gears in my R200LSD rear end for some 3.36 or 3.54 gears. I was wondering if I can swap right out on the 3.54 or 3.36 gears, will they fit or are the 3.70 gears that come in the LSD rear end different in any way shape or form. The problem I run into is my rpm's trap speed is just too much in the 1/4 mile. I am spinning my 385 sbc around 6800 plus rpm's, not great on a hyd. roller set up. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 29, 2010 Share Posted October 29, 2010 The easier move is to buy a 3.54 or 3.36 (rare) rear end and swap the LSD into it. I've done a writeup on it and it's in the FAQ section. Very simple compared to swapping gears. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted November 4, 2010 Author Share Posted November 4, 2010 Cool, thanks for your help. I will go check it out. Quote Link to comment Share on other sites More sharing options...
rucus01 Posted November 5, 2010 Share Posted November 5, 2010 The easier move is to buy a 3.54 or 3.36 (rare) rear end and swap the LSD into it. I've done a writeup on it and it's in the FAQ section. Very simple compared to swapping gears. I sent my diff to Devon at unitrax and had them install a set of these http://kameariusa.com/L6_r200.php They also installed a OS Giken LSD for me. Made a big difference. Quote Link to comment Share on other sites More sharing options...
Neverdone Posted November 5, 2010 Share Posted November 5, 2010 Yes but back to his original question for people a bit more budget restricted. Can those gears be swapped into the 3.7 R200lsd? Quote Link to comment Share on other sites More sharing options...
SATAN Posted November 6, 2010 Share Posted November 6, 2010 Yes but back to his original question for people a bit more budget restricted. Can those gears be swapped into the 3.7 R200lsd? The answer is yes. Things you need. Matching ring and pinion. Correct pinion length for the case. (short nose or long nose). correct shimming. Quote Link to comment Share on other sites More sharing options...
