Doc Hawk Posted November 11, 2010 Share Posted November 11, 2010 Has anyone ever swapped the stock steering column control stalks for something out of a newer vehicle? I am starting design on a full custom interior and I sure would like to take the opportunity to put some modern solid-state (or at least more reliable) turn/light/wiper/etc controls on the column. I didn't find anything mentioned after a few dozen searches. Thanks, David Quote Link to comment Share on other sites More sharing options...
Derek Posted November 11, 2010 Share Posted November 11, 2010 I switched every thing over to relays and use the stock switches to run the relays. Huge difference. Derek Quote Link to comment Share on other sites More sharing options...
Doc Hawk Posted November 12, 2010 Author Share Posted November 12, 2010 That's a good tip, thanks. I will likely be doing the same thing, but I want a more modern set of stalks to match the interior I'm building. I went junkyarding today and saw a set of column controls in an early 90's Honda Accord that might be well suited. Quote Link to comment Share on other sites More sharing options...
Berkeley110 Posted June 12, 2011 Share Posted June 12, 2011 were you able to find anything that worked? I would like to change mine out too and a set from a honda would probably work great. Quote Link to comment Share on other sites More sharing options...
iBang Posted June 12, 2011 Share Posted June 12, 2011 I'm planning on changing out the entire steering column for one that has tilt and distance adjustment and I figure I'll use the matching controls from my donor column for the since I can. I actually really like the feel of the column controls in my '05 accord and it has all the adjustments I want so unless it turns out I can't make it fit, that is likely the donor car I'll use for those parts. Quote Link to comment Share on other sites More sharing options...
