82 280ZX Will Not Start
I have an 82’ 280ZX that just stopped running and will not start.
 It is getting fuel.
 Coil is firing.
 With plug removed and touched to the block I get a very weak or no spark. But if I pull the plug away from the block I get a strong spark jumping from the plug to the block.
Does anyone have any ideas as to what is going on with it?
 Coil is firing.
check your wiring, cables, the electrical stuff. clean battery terminals with a solution of baking soda and water, or scrub the terminals, also clean connectors. the spark plug should be grounded when trying to test for spark, do you know the difference between a good spark and a bad spark? just wondering because i didn't really know till experiencing both. if your spark is weak, check gapping on plugs, then spark plug wires, then distributor cap and rotor, then coil. if all fails perform a compression check and start from bottom up using the beginner guide.
