somthinrandm Posted November 23, 2010 Share Posted November 23, 2010 I have A MSD 6400 well 6series black ignition box on my 77 Z The guy i bought it from had the ignition installed. He told me that the Tach was just not hooked up. The rpm white wire is disconnected and just sitting there, and there is ONE wire on the harness not connected to anything pertaining to the msd ignition. I was wondering if I need to buy the MSD adapter, and what kind should i buy? Does anyone else have a 280z with a MSD 6 series setup, did u need to use an adapter? im afraid to just connect the rpm wire to the extra wire in the harness, im afraid i might break something. thanks for your thoughts Quote Link to comment Share on other sites More sharing options...
2eighTZ4me Posted December 14, 2010 Share Posted December 14, 2010 If you're running a stock tachometer - you'll need the MSD8910 tach adapter. If you're running an AutoMeter or other brand aftermarket tach, you should be able to pull from the tach output on the MSD box. Quote Link to comment Share on other sites More sharing options...
hpltree Posted January 3, 2011 Share Posted January 3, 2011 ok so mine is a 73 with a 77 tach as the jtr manuel says do i still need the 1.5 kil resiter to get the tach to work.. or just the msd adapter? Quote Link to comment Share on other sites More sharing options...
NewZed Posted January 3, 2011 Share Posted January 3, 2011 I searched using these three words - msd 280z tachometer - and found some threads that will probably help you out. Not trying to be sarcastic, it really was that easy. Since this post should show up in your search, the sixth result down will probably be the one you want. Quote Link to comment Share on other sites More sharing options...
hpltree Posted January 4, 2011 Share Posted January 4, 2011 thanks.. this a good example of how we all spend hours searching things and not getting any answers.. after reading your post i searched for (msd 280z tachometer) and got your post only for a responce. after a few more trys i put in( MSD 280z tachometer ) and whala the caps on the msd made the diff.. i do search and look before i post but not always with good results.. maybe i am just a poopie head . i am better with tools than computers Quote Link to comment Share on other sites More sharing options...
NewZed Posted January 5, 2011 Share Posted January 5, 2011 Oops. Sorry about that, I didn't even know the Search engine was case-sensitive. Good catch, useful information, thanks. I must have used caps in my search then posted lower-case. I hope that's what you were looking for. Quote Link to comment Share on other sites More sharing options...
hpltree Posted January 5, 2011 Share Posted January 5, 2011 yes i think thats what i needed thanks again i will ty it out next day off after getting my adapter.. i will let you all know if she works Quote Link to comment Share on other sites More sharing options...
