Calico Posted November 30, 2010 Share Posted November 30, 2010 Has anyone ever swapped the single turbo vg30et into the z32 chassis? do you know if the vg30et would bolt in a z32 300zx? Quote Link to comment Share on other sites More sharing options...
sweetride2go Posted February 10, 2011 Share Posted February 10, 2011 I haven't seen it, but that doesn't mean no one has done the swap. I would think it would swap easily, since the single cam VG is a lot smaller on the top end. The only consideration I would have is the crossover pipe for the exhaust. And maybe the oil pan, but I've worked with both, and I don't foresee that as a problem... Ryan~ Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted February 10, 2011 Share Posted February 10, 2011 Why would you want to do that? If you want a single turbo setup I would get a VG30DETT and make a single turbo exhaust manifold and convert to single... Quote Link to comment Share on other sites More sharing options...
Calico Posted March 2, 2011 Author Share Posted March 2, 2011 cause u can get a new 3.3 (Vg33e/r) block from a pathfinder/villager ect for peanuts, make good power & then bolt on the turbo vg30et parts. Quote Link to comment Share on other sites More sharing options...
Pdfflyer Posted May 23, 2011 Share Posted May 23, 2011 The Z31 VG30ET engine required a specific crossmember as compared to the Z31 NA crossmember. I'm sure you could fabricate the changes into the crossmember for the Z32 car body. PDF Quote Link to comment Share on other sites More sharing options...
