Help - Fan Flex at high RPM causes Fan to Hit Radiator!
240zip
On my engine with an after market aluminum radiator, we noticed that with the fan clutch, the plastic fan actually bows forward about 3/4" which is just enough to touch the fins at 7000 RPM. The option we're looking at is to swap the OEM fan and fan clutch with an after market low profile fan. This is our first option and is being done as the 'low cost option'. It seems the best option is to go with an electric fan and shroud with a temperature switch.
The pictures aren't great, but you get the idea. It was a fairly stock set-up (mounts, engine, etc). Has anyone else had this problem of fan flex?
