Khaserwolf Posted December 6, 2010 Share Posted December 6, 2010 Ok i recently rebuilt the motor on a 78 280 Z, with L28 in it, The ignition set up is stock and the car runs but it sound like it missing between 2000 and 3500 rpm and when we took a timing light to it. well.. lol it reading off the timing marks (sever retarded timing) lol. So my question is 1) what should the timing gun read, in other words what is the stock timing degree it should read. (plz forgive my terms, im new to some of these fields) 2 I learned how to cheak to see if the TPS or (throttle positining valve), but i dont know what is the normal resistace it should be reading when you cheak it with a multimeter. Any suggestions will help Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 6, 2010 Share Posted December 6, 2010 You can't go wrong here - http://www.xenons30.com/reference.html The EE and ET chapters will tell you a lot about your timing. The TPS is covered in EF. Once you get these figured out, you'll probably have more problems to work out so it's best to have this on hand. Kind of surprising that you rebuilt the motor but you're new to ignition timing. Just saying, it's interesting. How did you rebuild the motor without the FSM? Quote Link to comment Share on other sites More sharing options...
Khaserwolf Posted December 6, 2010 Author Share Posted December 6, 2010 lol ok about the motor rebuld comment lol. a friend showed me and was teaching me. But basicly i did 90 percent of the labor. My first overhaul .And the guides i have could be a bit better. But im a look at that link now and see whats up. Quote Link to comment Share on other sites More sharing options...
