Advice Please, Turbo on Stroker Motor
kevinz
I have a stroker motor that I would like to put a turbo on. It's an N42 block bored to 89mm, v07 crank, 240z rods, Ka24E pistons(cast). I have two different heads that I can use. I have an N42 that is ported quite a bit. It has a .480 lift 274 duration cam. The other is a stock P90. With the N42 I would have about 11:1 compression. the P90 would have about 9.5:1 compression. What could I safely boost on this motor. Or should I get rid of it and put in a stock turbo motor and go from there. If I can use this motor safely, I will be using a haltech e6, msd 6al, and mallory unilite, so I should be able to tune it pretty well.
What do you think? Any advice would be greatly appreciated.
Mate, you can turbo anything.
You could work the P90 to increase chamber size and/or use a thicker headgasket to lower your compression ratio into the eights.
Ditch that cam and get something that works properly with turbos. An "A" spec stocker is a good place to start.
A low boosted (less than 7 psi) stroker would be a torque monsta
Do it, you know you want to B)
