big-phil Posted January 30, 2011 Share Posted January 30, 2011 low beams not working in the 78 has been a problem, this is how i fixed mine. Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted May 5, 2012 Share Posted May 5, 2012 This just made quick work of fixing my low beam issue. I hope the admins see this and make palce it in the FAQ electrical section. Thank big phil, once less bald patch in my beard. Quote Link to comment Share on other sites More sharing options...
Kash Posted May 6, 2012 Share Posted May 6, 2012 I'm having a little different problem, the high beam on the right side (only) of the car comes on when I turn the parking lights on. I replaced the switch but that did not help and it switches to low beam when I trun the switch to the head light position...any ideas ('78 2880z)? Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted May 6, 2012 Share Posted May 6, 2012 If you don't have a multimeter I would buy a cheap one at harbor freight or walmart for 10-15 bucks. Check for voltage at the fuses, then at the connector. My first bet would be that you have corroded connections at the pigtails. You can remove the rubber plug from the back of the plastic connector and remove the push on connectors, try to clean them with some sandpaper or steel wool, then make sure they are not loose and try again. Quote Link to comment Share on other sites More sharing options...
