Dunlop Posted March 10, 2011 Share Posted March 10, 2011 I have a T-56 transmission and i have the driveshaft that goes with it and also the jtr end. But what do i use for the piece that connects to that? I know that it uses a dana 1310 u joint but on the driveshaft i have is a little bigger. Have searched and am confused. Please help Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted March 10, 2011 Share Posted March 10, 2011 You need to buy the JTR swap manual. It gives you all the info you need to handle the easy stuff like this. Considering the overall cost of doing the swap the 40 bucks on the manual is dirt cheap considering how much it helps. Quote Link to comment Share on other sites More sharing options...
Dunlop Posted March 12, 2011 Author Share Posted March 12, 2011 On 3/10/2011 at 1:22 PM, emeraldlion said: You need to buy the JTR swap manual. It gives you all the info you need to handle the easy stuff like this. Considering the overall cost of doing the swap the 40 bucks on the manual is dirt cheap considering how much it helps. I have the JTR manual. I also bought what the manual told me too. I think i found someone that can help me, i will post pics. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted March 12, 2011 Share Posted March 12, 2011 if the lengths correct you can buy adapter /conversion u-joints http://www.mrdriveshaft.com/U-Joint%20Page.htm#Neapco%20Conversion%20U-Joints Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted March 16, 2011 Share Posted March 16, 2011 Any one know the spice part number for the rear diff flange? I know I can get one from JTR but would prefer to get one locally. Quote Link to comment Share on other sites More sharing options...
Trevor Posted March 22, 2011 Share Posted March 22, 2011 NEAPCO 2-2-899-1 for R200s thru 1978 (except 1975). Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted March 22, 2011 Share Posted March 22, 2011 If you're going to use a driveline shop to section/phase/balance the driveshaft they should have everything you need, the adapter too. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted March 24, 2011 Share Posted March 24, 2011 Thanks, I have the late 75 with the flange that is square like in the JTR website. I just got it today only to find out i need the DAT-110. I was going by the pics, since i did not have a tape measure (wife took it somewhere). JTR does not tell you that if you return an item to get you money back they charge you a 20% restocking fee. I'll see if the driveline place will do an even swap with me. Thanks! Quote Link to comment Share on other sites More sharing options...
Dunlop Posted March 24, 2011 Author Share Posted March 24, 2011 Well got it back and the place ended up doing it wrong. The measurement from output shaft to rear end was 23-9/16 tight. The machinist put it at 23-9/16 to the center of the u joint. However it did look really nice. will update Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted March 25, 2011 Share Posted March 25, 2011 You and i are never going to get our driveshafts done huh? Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted April 4, 2011 Share Posted April 4, 2011 Trevor mentioned, NEAPCO 2-2-899-1 for R200s thru 1978 (except 1975) as being the flange yoke we need to use and I believe this to be incorrect. Below are the spcecs. for that flange and they do not match the one I received from JTR. JTR uses a 1310 U-Joint and the 899 uses a 1210. Some of the dimension are similar but others are not compaired to the JTR flange. My take is that these are custom flanges from JTR because even if you research the Spicer 1310 series flange nothing matches the JTR. Flange Yoke 1210 series, 4xØ.328 Holes on 2.750BC, Ø2.250M pilot Spicer 2-2-899 Code: SPI-2-2-899 Price: $52.43 Design Style Snap Ring Design U-Joint Series 1210 we need 1310 Universal Joint Retaining Width 2.688 we need 3.469 Universal Joint Bearing Diameter D 1.062 Flange Diameter A 3.406 Bolt Circle Diameter B 2.750 Horizontal Distance Between Holes (center to center) 0.000 Vertical Distance Between Holes (center to center) 0.000 Bolt Hole Diameter .328-D Bolt Hole Quantity 4.000 Pilot Diameter (M-Male, F-Female) C 2.250M Centerline of Joint to Flange Face G 1.484 Compatible U-Joint Kits SPI-5-443X,SPI-5-736X Notes Fits several Nissan & Toyota pick-up trucks Cast/Forged Quote Link to comment Share on other sites More sharing options...
Trevor Posted April 5, 2011 Share Posted April 5, 2011 (edited) http://forums.hybridz.org/index.php?showtopic=2881 see Pete's note Posted 11 December 2002 - 05:53 PM Edited April 5, 2011 by Trevor Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted April 7, 2011 Share Posted April 7, 2011 On 4/4/2011 at 3:49 PM, Danno74Z said: ... My take is that these are custom flanges from JTR because even if you research the Spicer 1310 series flange nothing matches the JTR. ... I don't want to steer anyone wrong. It was several years ago when I had mine made and my info may be out of date. I brought the shop (Drive-line Service of Concord, CA)my JTR adapter and they smiled and told me it was an off the shelf part (might have been at that time and now no longer). Sure enough, he went in the back and came back with an exact match. They also told me that they made drive shafts for Scarab back in the day, so maybe it was an of the shelf item for them only. Either way, just want to make sure I'm not causing more confusion while I'm trying to help. Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted April 9, 2011 Share Posted April 9, 2011 Trevor is correct NEAPCO 2-2-899-1 is flange to use on the Z and is the one JTR sells. The 1 after 899 is the key to getting the correct flange to match the 1310 u-joint and the other dimensions. Sorry. MSRP: $77.24 Price: $32.44JTR sells the flange for $65 You Save: $44.80 (58 %) Item Number: N2-2-899-1 Manufacturer: NEAPCO Manufacturer Part No: N2-2-899-1 1310 Series, Use Kit No. 1-0153, A-3.469, B-1.063 * D - Swing Diameter: 3.600 * E - Bolt Circle: 2.750 * F - Hole/Thread Size: .323 * No. Bolt Holes: 4 * G - Pilot Diameter: M-2.250 * Joint Angle: 15 Degree * H - Flange Face to Centerpiece: 1.625 http://store.gregoryssupply.com/series1000standardcompanionflange-bore1125-1-1-1-1-1-1-1-1-1-1-1-1-2-1-1-1-1-1-1-1-1-1-2-1-1-1-1-1-1-80.aspx Quote Link to comment Share on other sites More sharing options...
