aliga Posted March 12, 2011 Share Posted March 12, 2011 Will the 7.5 LH8 pan work for a ls1 swap into a Z with the jtr mounts. Thank you. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted March 12, 2011 Share Posted March 12, 2011 Not if you want any ground clearance. F-body pan is 5" deep and the LH8 pan is 7.5" deep. The mounts for the LS1 are from JCI(John's car inc/broken kitty) not JTR. JTR does sell headers that work with the JCI mounts. JTR sells mount for old gen 1 and 2 small block chevys. Quote Link to comment Share on other sites More sharing options...
aliga Posted March 12, 2011 Author Share Posted March 12, 2011 i read that the f body pan is 5.5, i will try chopping it down, i bought a pan from ebay, and the seller mislead me. Quote Link to comment Share on other sites More sharing options...
cockerstar Posted March 12, 2011 Share Posted March 12, 2011 How did they misslead you? If they did you should be able to get your money back through paypal Quote Link to comment Share on other sites More sharing options...
tx240z Posted March 13, 2011 Share Posted March 13, 2011 the lh8 pan is good for truck swaps so you might try selling it on a truck forum Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 13, 2011 Share Posted March 13, 2011 Will the 7.5 LH8 pan work for a ls1 swap into a Z with the jtr mounts. Thank you. aliga.... PM sent to you. Quote Link to comment Share on other sites More sharing options...
badboyz31 Posted March 14, 2011 Share Posted March 14, 2011 so what is the best for the LS in the s30? f-body? Quote Link to comment Share on other sites More sharing options...
lowdown Posted March 17, 2011 Share Posted March 17, 2011 I havn't found one for my swap but someone posted on my thread The GM oil pan/pickup/windage tray options are '98-'02 F-Body LS1 or '05-'07 Y-Body LS2. Quote Link to comment Share on other sites More sharing options...
Boy from Oz Posted March 17, 2011 Share Posted March 17, 2011 so what is the best for the LS in the s30? f-body? I bought these item back in 2007 and they worked out fine; C6 LS2 oil pan (has shallow rear sump) (kit with bolts/gasket) = 12581810 C6 LS2 oil pick-up screen (same used on LS6) = 12558750 C6 LS2 oil deflector (same as used on LS6/LS1) = 12558189 C6 LS2 dipstick = 12570788 C6 LS2 dipstick tube = 12570787 Quote Link to comment Share on other sites More sharing options...
badboyz31 Posted March 18, 2011 Share Posted March 18, 2011 I bought these item back in 2007 and they worked out fine; C6 LS2 oil pan (has shallow rear sump) (kit with bolts/gasket) = 12581810 C6 LS2 oil pick-up screen (same used on LS6) = 12558750 C6 LS2 oil deflector (same as used on LS6/LS1) = 12558189 C6 LS2 dipstick = 12570788 C6 LS2 dipstick tube = 12570787 you sir are the man! Quote Link to comment Share on other sites More sharing options...
