mistah mofro Posted March 17, 2011 Share Posted March 17, 2011 So i got my front techno toy tuning camber plates in and my rear going to be done by the end of the month. I was wondering what you guys use as a "strut bar" after the plates are welded in, since the traditional ones usually bolt right onto the strut towers. thanks. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 18, 2011 Share Posted March 18, 2011 Weld a clevis to the strut towers and then either make your own bar or adapt one. If you're running an L6 you need the bar to be bent, or you need to make the clevises long enough that they clear the valve cover. If you are running a V8 or a shorter motor, you might be able to use a straight bar with a lower profile clevis which would be stronger. Quote Link to comment Share on other sites More sharing options...
