O-Ring Custom Fuel Rail
I know this is not new, but I wanted to share my Fuel rail concept.
So, I start with buying a few extrude bars...
I found some drawing here on hybridz to get an idea and start modeling with mine design software.
An haft-hour later I got my print and I start it.
I used a Aluminum 6063 Dash-8 type bar and I made ​​thread and 90 deg chamfer to allow the insertion of fitting with an tight fit O-ring.
I use 6 x 5/16 Hose Barb to AN Adapter Fitting with Boss O Ring and 2 x fitting -6 AN Flare to -8 AN Boss O Rings.
I choose use the -8 AN fitting because the Alu. Dash-8 bar has an ID of .690".
Which is exactly the measure needed to thread the AN -8.
For the 5/16 Hose Barb Adapter I made a 60 deg chamfer on the fitting.
I've done the same thing then the -6 AN to -8 AN for the tight fit O-ring.
Those are greats, because I can use my stock injectors are use an bigger one.
The next setup is to make a pressure test and polish it.
But, I am very optimistic that it will support more than 50 psi easily.
If everything goes well I will start a few more for my 300zx car on Dash 6 bar.
I hope this inspires some of you
Enjoy!
Here are some pictures and more on: Nismo_zxt L28 Fuel Rail
Edited by nismo_zxt
Thank cockerstar!
I use them instead of those with barbed fitting with NPT threads.
The NPT must have an precise thread with perfect diameter and depth to get an nice seal.
With the -AN thread, it's much more easy to do.
Just add the right chamfer for the o-ring and you got an perfect seal.
All the drilling, chanfer and taps on the rail has been done on an milling machine.
So they are perfectly perpendicular to the base.
I use a standard 90deg 3/4in Countersink for aluminum.
This was mounted on 40 Shank/End Mill Adapter.
  • 8 months later...
