L28et alt problem help
mldub2
I have a 75 280z turbo I am using a new 75 alt and a new battery and new voltage regulator. My car starts good and run ok right now as long as my battery is charged once i drive it for a little bit It runs like ****. Then back to charging it again.
So I had it tested and they said it's good. What else can it be grounding straps maybe. Any help.
Are you sure that the wires to the alternator and regulator in the car are connected properly? Plus a good ground to the alternator case (check with ohm-meter)? And fusible links are all intact?
The auto parts store testers are wrong occasionally. You should test with a volt-meter (not the dash gauge) at the battery, in the car, at idle and higher rpm.
What is your Charge Light doing?
