skirkland1980 Posted June 25, 2011 Share Posted June 25, 2011 Sorry to hear your having so much trouble. I visited your thread because I am interested in converting mine to a crank trigger setup. Also good luck with your Innovate LC-1. My first one was bad out of the box. Summit replaced it, the next one lasted a month, then I swapped it with an Autometer unit and I love it! Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted June 25, 2011 Author Share Posted June 25, 2011 So far my LC-1 is good. I look forward to sharing my lessons learned - as soon as I learn them! Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted June 30, 2011 Author Share Posted June 30, 2011 SOLVED!!!! One. Wire. After mucho hours and dollars, it came down to one issue - timing. No matter what we told Tunerstudio, the timing stayed at 10 degrees. Megasquirt wasn't commanding advance on the EDIS module. While I went to Pull-A-Part and bought two extra EDIS-6 modules (anybody want to buy one? $20 each!), a friend disassembled my ECU and inspected the jumper wiring. It turns out that the Megasquirt ECU was incorrectly wired to directly drive a coil, rather than command EDIs. We moved the IGN jumper wire to JS10 where it should have been, plugged it up, cranked the car, and the throttle responded! It definitely needs tuning, but my problem is solved!! Quote Link to comment Share on other sites More sharing options...
JSM Posted June 30, 2011 Share Posted June 30, 2011 So after ALL this how many Electromotive units could you have purchased! Sorry I couldn't resist! Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted June 30, 2011 Author Share Posted June 30, 2011 Hah! You had to go there. I really did want to know everything about my engine, and now I feel confident that I can troubleshoot just about anything. Quote Link to comment Share on other sites More sharing options...
