200ZR Mounts No Good on Z31 Crossmember
#1 Guest_RB25DET Z31_*
Posted 13 June 2006 - 09:18 PM
After bolting them to the block, I noticed they will NOT work on my stock crossmember. I am a bit confused after hearing so many others who claim that these mounts bolt straight up to the factory crossmember with no modifications.
The mounting holes are perfectly aligned horizontally, but on my crossmember the holes are spaced at least 2 inches apart. I know someone else on here mentioned the exact same thing a few months back, as well as the fact that the hood will not clear the engine.
I will be making doing some cutting and welding for the mounts this weekend, unless I can get my hands on a 200ZR crossmember or pull a rabbit out of my ***. Either way, not likely. Comments . . . ?
#2
Posted 13 June 2006 - 10:17 PM
RB25DET Z31 said:
Oo0o0ohhh Ohh!! pull a rabbit out of your hat, pweeze !!1!shift+one!
#3
Posted 13 June 2006 - 10:55 PM
#4
Posted 15 June 2006 - 08:21 PM
It looks like you and I are working at about the same speed in our swaps. What year Z31 do you have? Do you have any pics of what you have done?
Later
#5
Posted 20 June 2006 - 06:17 PM
I found out today that you do not need custom made engine mounts, If you have a N/A Z31.
Are you ready for this... Cut the existing mounts and flip them around, this will make them 2 inches further forward for your mounts. Also I was emailed today that MGPauto can get 200ZR crossmembers. Here is a link to his website. http://www.mgpautoparts.com. Ryan informed me that it will take about a month to get the part to you and about $600 shipped.
Good Luck!
#6
Posted 21 June 2006 - 02:36 AM
Quote
Are you ready for this... Cut the existing mounts and flip them around, this will make them 2 inches further forward for you mounts. Also I was emailed today that MGPauto can get 200ZR crossmembers. Here is a link to his website. http://www.mgpautoparts.com. Ryan informed me that it will take about a month to get the part to you and about $600 shipped.
Good Luck!
Why not just get a Z31 N/A Crossmember? I'm sure you can find those at any local junker.
#7
Posted 21 June 2006 - 06:38 PM
Quote
Exactly, I have a N/A so that is what I will be using. The crossmember should be dirt cheap also.
Hopefully RB25DET Z31 got this message before He paid for some new mounts to be made.
#8 Guest_RB25DET Z31_*
Posted 22 June 2006 - 07:17 AM
The engine sits perfect, and actually sits about 3/4 inch further back than it would with the 200zr mounts and crossmember. I did NOT have to relocate the radiator or beat the sh*t out of the tranny area to get it to fit right (although I could not fit the speed sensor). Will post pics in a day or so. Good stuff, good stuff. Hope ur projects are coming along as well.
#9
Posted 22 June 2006 - 11:04 PM
RB25DET Z31 said:
is there a reason why you're secretive?
#10
Posted 24 June 2006 - 03:38 PM
Quote
How did you use the turbo crossmember? I could have sworn that one mount faces forward and the other faces backwards?
Like this ? the n/a crossmember is on the top, turbo on the bottom.
#11
Posted 25 June 2006 - 07:34 AM
Careless said:
Yeah, I would like to know also.... as it being that this forum is ALL ABOUT HELPING OUT YOUR FELLOW Z guy, I guess I should take my RB writeup down so that no one can learn from it, and so no one could have bitchen cars...
$0.02
#12
Posted 26 June 2006 - 06:39 AM
Quote
$0.02
i should probably PDF that writeup before you do that. hahahaha
#13
Posted 26 June 2006 - 09:49 AM
Quote
$0.02
NOOOOO!!! I usually read that at work. I really need that for my future RB swap, well let me pdf it in case =). BTW good job on writeup.
#14
Posted 26 June 2006 - 12:38 PM
jtmny1999 said:
Oh man, I'm due for an update!
#16
Posted 27 June 2006 - 01:50 AM
DaveZ31turbo said:
There are, Just gotta upload them... too busy with work, etc...
#17
Posted 27 June 2006 - 10:58 AM
You need to sell me your exhaust manifold! I want it! You really want to give it to me! Hahaha, but really I would like to have an aftermarket cast manifold, if you happen to come across another one. Please let me know.
#18
Posted 27 June 2006 - 03:10 PM
Quote
I'm planning on selling mine if the offer is right... I don't know how much but you can start now!
#19 Guest_spxaznboy_*
Posted 02 February 2008 - 04:46 PM
#20
Posted 02 February 2008 - 09:50 PM
spxaznboy said:
i think one of the mods can move this thread to the proper place, but anyhow, you're better off getting some things together from both cars if you're serious.
being cars from the same chassis, you would have more targetted info going to xenon's, az-bum's, or any other Z31 focused websites. For the z31 being one of the least sought after/purchased z's (is what i've been hearing, even though I own one and love it so far.), they seem to have the most information available on websites. I believe because the information is pretty close to where the car is cheap enough to mod, and a very good base, compared to what today's sport compact cars and z cars cost.
but EITHER WAY, you should at least make a build up thread in the members rides section, or the v6 nissan section, and report your findings and exercises you've taken to make it work
Help
