Converting T350 to 700r4 in a 74 GMC Jimmy
  • Please log in to reply
3 replies to this topic
#1 gofast1320
gofast1320
    Newbie
  • Members
  • Pip
  • 1 posts
  • LocationGrand Forks,ND
Posted 18 December 2016 - 02:10 PM
Please help! Im trying to put a 700r4 into my 74 GMC Jimmy which has a T350 in it now. Is this possible ??
Any info would help.
Thanks
#2 calZ
calZ
    Regular
  • Members
  • PipPipPip
  • 99 posts
  • LocationCalifornia
Posted 18 December 2016 - 02:20 PM
This is a Datsun Z forum. While you might randomly get some help here, it's unlikely.
#3 jhm
jhm
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 560 posts
  • LocationHampton, VA
Posted 19 December 2016 - 06:49 AM
http://www.bowtieoverdrives.com/
#4 skirkland1980
skirkland1980
    Junior Member
  • Members
  • PipPipPipPipPip
  • 880 posts
  • LocationMarietta, GA
Posted 20 December 2016 - 09:23 AM
Yes it's possible. If its 4x4 you'll need a 4x4 transmission. The 700r4 is longer so driveshaft length and crossmember may change. Also will need the linkage for the tv cable and it will need to be properly adjusted.
:1983 280zx turbo, L28ET, custom cam grind, 96 saab 900 intercooler w/2.50" piping, 3" mandrel bent exhaust, megasquirt II v3.57, 540cc injectors, walbro gsl392 255lph fuel pump, aeromotive regulator, -6 supply lines, custom fuel rail, MSD ignition wires, MSD 8202 coil, homemade boost controller, Garrett TC4305 turbo, 70mm throttle body, Godzilla BOV, Turbonetics wastegate, custom intake, custom turbo header, Cooling Mist H2O/meth injection, 20psi boost, all stock body, stock interior and weld draglite wheels, TH350 trans 4000 stall with B&M 'street stick' shifter and hughes trans brake, nitto nt555R drag radials, best 1/8 mile of 7.53@ 98 mph
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
