Leaderboard
Popular Content
Showing content with the highest reputation on 09/20/20 in all areas
  1. Hey guys, I've been a long time lurker but just seeing if there would be any interest for a weld-in chassis strengthening kit. I couldn't find anything on the market, so I decided to make one myself. I'm located in Sydney, Australia and will happily ship these kits overseas if there is enough interest. To register your interest (no commitment or deposit required) just follow the group-buy format of e.g. 1. sabiauto 2. ... At the moment this is just to see if there is enough interest for me to mass produce it. This will be developed by myself, an ex-automotive engineer (I'm now in software of all places) and one of my ex-managers who is an ex-Prodrive rally engineer and ex-Holden engineer. The main priority for this kit is to: (i) Prevent cracks, tears and fatigue without loading up other areas (ii) Strengthen front and rear strut regions to retain car geometry (iii) Strengthen the floorpan and the tunnel. Naturally the tunnel will provide most of the cars mid-section strength, but we think it can be better tied in than just spot welded around the footwell. (iv) Maintain an OEM appearance after applying seam sealer. Anyone with a Z will know it's different, but otherwise it appears to be stock. Without a CAD model for the car, we cannot complete proper FEA modelling so in terms of how much hp or torque the chassis can support, it'll be up in the air. However in the past we've designed and engineered (for internal prototyping) engine swap and reinforcing kits to test different engine combinations in different chassis' for OEM manufacturers and we're also quite fond of the S2000 chassis as a benchmark design. If there is enough demand, I'll properly get it sorted with engineering drawings and work with a fab shop so each kit is toleranced, tested with a few Zs before mass production, professionally cut, bent and primed. Price-wise it will probably be in the range of $3000 AUD for a full kit. I have some light demand from a handful of fellow Aussies but we don't have that many Zs here. I spent a few hours inspecting the Z shell and it's probably going to end up as a 32-pc full kit. I've mocked out which areas I'd like to strengthen and did some calcs + impact considerations. This is not a replacement kit for a full roll-cage though, I am primarily looking to update the 240z chassis and ensure that it can adequately handle more power with spot welds popping off, chassis flexing, twisting and fatiguing. It will include: - 10 x square angle gussets (street: 8pc, performance: 10pc) - 4 x flat plates (street: 4pc, performance: 4pc) - 9 x rails / rail extensions (street: 6pc, performance: 9pc) - 6 x reinforcing structures (street: 2pc, performance: 6pc) - 2 x full sill length tubes (optional + performance only, this can only be installed if you have the outer sills removed) - 1x underbody butterfly brace (optional + performance only, bolt on part but requires you to drill through your floors) I'll probably make 2 kits with 2 optional extras: (a) Street kit (20-pc kit) (b) Performance kit (29-pc kit) (c) Options - 2x full sill length tubes - 1x underbody butterfly brace It will be something along the lines of this (NOTE: these are random photos we took off the internet of a kit for a mustang I think and an S2000 diagram as a guide);
    1 point
  2. Hi All, I am JC, I currently live in Paris area (France), and after lots of japanese cars I had (S13, Civic, Corolla TS, GT86, EX37), I am currently buying an imported '78 280Z. Project is subject for full restoration, and maybe engine swap, as I currently have one in hands Although L28 seems to be a good base, so it is under consideration. Nice to find such a board See you all around!
    1 point
