It's been a while. I moved from NC back to OH for work. My tools and vehicles have been locked up in a storage unit while we are in the process of buying a home. I took the car back to my parents' carport to try to get some work done. However, there were a lot of little things to do. There is a fuel smell on refills, exhaust fumes leak into the cabin, the carbs need tuning, and my shitty rust repair needs some work. Because there was so much to do, it made sense to me to pull the engine. Since I was pulling the engine, it made sense to me to just swap in an RB25.
So I pulled the RB from the parts car, pulled the L24, and started fixing all my previous work. My welding has gotten a lot better, but it still has a long way to go. The thicker sway bar and improved suspension was tearing the frame rails apart where the sway bar attaches. So I drilled and tapped some thicker steel and 3/4 boxed the frame rails to try to prevent the same damage in the future. I scuffed up the engine bay, threw some primer at it, and painted it the same white as the rest of the car. I also pulled the dash, stripped the paint, put on some rust preventative paint, and added sound deadening.
Next steps: I need to drop out the stock rear end and get an R-200 with an LSD in it. I have a new universal harness to go in it and new gauges in a crack-free dash. I need to figure out what brakes I want to upgrade to. I also need to figure out if I'm going to reuse or replace all the brake lines, fuel lines, and gas tank. I also need to chose what ECu I want to use. Right now, I'm leaning towards a Haltech Elite 1500. Finally, I need to rebuild the RB25 with the oiling upgrades and get it and the RB25 transmission thrown back in the car. I'm spending more hours at work in my new role, but I'll try to post updates. Photos-3-001.zip
