I am finally getting back to working on my LS swap after 10 years of it sitting.
I initially installed my LS using John's Car's mounting kit several years ago. I have since put Austin Hoke's mount kit in.
My original Sanderson shorty headers would need mods to work and I'm looking at Hawk's and CX racing long tubes. Leaning towards the CX ones as they appear to fit tighter under the car and in the engine compartment. I realize they are smaller primaries, but I'm not worried about finding the last few horsepower.
I'm using a C&R 26 x 19 double pass rad with bar and plate oil cooler, does anyone know if I'll be able to route oil cooler lines between the block and headers? This would be very tight with the Sanderson's.
I'm pondering the Silvermine electric power steering kit. will it clear either Hawk's or CX? Read in a post that on a 280, the EPS hangs a bit below the dash, this may be an issue for me as I have a prosthetic left leg and with no ankle joint I have to deliberately put my foot higher on the clutch pedal.
Also looking for opinions on cooling fans, any idea how many CFM a LS would need? Running A/C, so there will be a condenser out front also.
The core is 22 inches wide, and looking at Spal catalogue it looks like I can just squeeze one 10 inch and one 11 inch fan on a custom shroud.
Combo would be well sealed to the rad support and ducting between the grill and support will be installed.
I'd like to run dual fans, so the trinary switch on the A/C will trigger the second fan.
Thanks in advance for any ideas, opinions, and pictures, Martin.
