240Z Turbo
Posts posted by 240Z Turbo
I have 3 that are sold and the cost was $600. The cores retail for $799 alone. The 3.5" version supports 900hp and the 4.5" version supports 1100hp. Garrett pricing just went up so I don't know how much the core will cost me in the future. It may add another $100 to the cost. However, that is still a great.
Joel, you can see your 4.5" thick endtanks in the background. It appears it will fit well, but cannot say it will clear the shocks for the 75-78 front bumper . The inlet/outlet center-to-center measurement is 31.625" and lines up exactly with the large holes in the radiator support crossmember.
I am doing a custom intake for JTaylor's RB25DET if he ever gets off his rear and ships me the intake runners . What is a V-mount intercooler?
Well, I think I can beat the 134mph, but not too sure about the 10.08 on the nitto drags.
Uh-oh is the ol' GNZ's time at risk.......... I mean if the man himself is saying "my arse is toast" that must mean something......
It means he is being a smart-arse
The results are in with the new powerglide.
451hp/509ft-lbs@wheels
Boost was set to 28psi and I was NOT running the nitrous.
The car is running pig rich so I suspect it will gain another 40-50hp@wheels with tuning. I am pleased considering this is using an auto tranny which typically read lower than stick cars on the dyno. The last time I dynoed the car it read 311hp@wheels and ran 129.6mph in the 1/4 the following day . Unfortunately, I did not have my nitrous bottle back from being filled. I will run the car in two weeks after I get the transbrake hooked up and new front tires. Anyway, not too bad considering the head only flows 200cfm on the intake ports
I'm really interested in this now' date=' as I'm making some [u']dramatic[/u] progress on my project and will need this in the not-so-distant future for fitment.
Whats the word?
The bird is the word
The cores are at my buddies shop right now and should be done by wednesday. I will contact you and send pics when complete.
You should say motor as the car gets about a 5.5 on a scale of 1-10. However, when I took my car out last night(all damn dirty) a guy at the gas station pulled up and said he really liked my car.
Anyway, I have no doubt I will now get the 10sec timeslip with the drag radials.
Here are the details. My swap works great and I am happy
Yep, powerglide swap complete and 1st testdrive today before the big storm hits. 25psi and 40mph lights the nitto drag radials. Car got a little sideways Never did that before with the old tranny
Oh yea...I am excited
I have all the stuff for the swap if you are interested.
Update
Russ ran a trial fit of the pan and it fits in his setup. Clearance between pan and front crossmember is about .5". He did state the pan had to be put into place once the motor was in the car. No way to get it in if you are putting in engine/trans as one because of the angle required. Also, it will be a good idea to purchase the mounts from Brad D to set the motor back as far as possible so you have the proper pan clearance. He will be making the oil pickup and I will duplicate them along with a baffling system.
I follow what you were saying regarding you timing curve. I think everyone has hit the nail on the head, not enough boost. Larger turbo's need to see more boost to hit their sweet spot. I will try to stay away from an sexual anologies here.
Jason,
I was a bit confused regarding your timing map. Here is a timing map I used to run. It is aggressive under boost so you may want to back it down 3-4 degrees. However, it gives you a good idea of how to formulate a timing curve.
Maybe it's a silly question but...
What if I only want to get to 300-ish rwhp? Is there money to be saved on a smaller core?
Thanks!
Brian
Not really, the pricing on Garrett cores is all pretty standard. I have one of two costs for the cores and the difference is rather minimal. Whether it is a large core or small core my cost is almost the same.
As you may know I am a Garrett Dealer. Sick of the damn prices of Spearco and the 8week wait on cores. I will be making 5 custom intercoolers for the early 70-78 Z car. I will initially make 2 to get feedback and have already sold one to John T for his RB25 powered 280Z. These use Garrett GT cores with core dimension of 24"(wide)x12"(tall)x3.5"(thick) and they support 900hp. The tanks will be built with the inlet/outlet to your size specs and directly facing the 2 holes at the top of the front crossmember. These cores are cross flow and are the highly efficient tube/fin design. Price will be $600 until the core prices go up. This price includes the fabrication of the end tanks. I will post a pic of what I mean in the morning. Please let me know if you would like the other intercooler for your setup. BTW, Joel S purchased the 4.5" thick version of this core for his RB26 powered 260Z. His core supports 1100hp. The 4.5" cores gives it that badboy skyline feel
Wow, I started to feel bad about not making more intake manifolds
And then I got over it
The intake has been sold and I will not be making more. Pain in the rear with little monetary reward for $300. I did it mainly to help out some Z folks with aftermarket support. It did not have air hons, but it still out flows the stock manifold and it out flowed a fully modified N42 intake manifold. It sucks when folks tell me it is not worth $300. So my response is go and have Hogan's make you at custom intake for $1300.
Not making any more of these intakes
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7913513680
I just ordered the remaining exhaust material to finish my new oval spintech exhaust system. The car is ready to run with the new powerglide once this is done. I want to run the car at the track and score some 10s timeslips. After that I plan to sell the car to finance the 3RZ powered RX7. I will do another Z when I can do the AWD RB26 swap. I just can't chunk down 5K to get the front clip that is required to do the swap. I can always get another 240Z for cheap. I am not worried about the fabrication involved, but I will need a shop to do that kind of swap. Although ScottieGNRX7 converted to the dark side of the force, I will not give in to the dark side!
James/Tim... specs?
The turbo is a GT42R. It is a Garrett full ball-bearing unit. It is flanged for a t4 and has a 4" v-band discharge. The inlet is 5" and the compressor outlet is 3" v-band. The a/r on my turbo is 1.01 and 1.15 for Tim's. This version of the turbo flows 85lbs/min and will support 900hp. There is another version of this turbo sometimes referred to as the GT42RS that flows 95lbs/min. This turbo should outspool Tim's T64 even though it is a much larger turbo. The cost on this turbo is $1950
I woke up this morning to find it trying to eat my 1year old son
Oh yea, it is a MONSTER
This turbo only supports 900hp. It is for my next project car. I purchased an 87 rx7 and am swapping a Toyota 3RZ (2.7L Tacoma) motor into it. I also have my intercooler, 24x12x4.5 Garrett GT core.
BTW, TimZ recieved his today as well. His L28 should be seeing 650hp@wheels with this new turbo.
So you can keep your silly little pan I dont need it.
Ahhhh
70-78Z Specific Intercoolers - PICS
in Turbo / Supercharger
Posted
I sent you an e-mail
Paypal amount is $635 shipped
turbo@speedshopthagard.com
I only need to weld on the mounting bungs to the top/bottom of the core so you have something to mount your bracket to. Monday is a holiday and the hurricane is about to slam us this weekend. I will probably be able to ship it on Wednesday.
