dj paul
About dj paul
- Birthday 10/24/1986
Contact Methods
Website URL
http://photobucket.com/albums/a172/djpaul8/
dj paul's Achievements
10
The actual loose nuts in the body side of the transmission mounts are stripped out. I am referring to the protrusions in the transmission tunnel that have those nuts in them. This is on a 71 240Z. I have a few ideas but all would seem to take too long and I'm just wondering what most people do when this happens. My searches have been fruitless. Thanks in advance.
S30 independent rear suspension
dj paul replied to MONGO510's topic in S30 Series - 240z, 260z, 280z
240sx IRS Photobucket This should help anyone wanting to do the 240SX IRS swap. I have lost the measurements. I believe Maichor (spelling?) was the one who inspired me to do this. He did a vella rossa spider replica. If i see a big response, ill remeasure everything and post. -
I was just wondering what would technically be the best setup. I can't seem to find the post but there is a picture of someone using the stock crossmember to mount the sr20. Would using these stock mounting location with custom mounts on the front of the motor be ok? or would using something like the mckinney motorsports package be better? Im guessing ease of install would be better with the mckinney or vildini package. Im just making sure no major problems could arise from this since i havent seen the stock mounts used much.
Thats awesome!. Anyways just to clear something up quick. you dont need high octane for 9.5-1 (unless your turbo it with that for some reason) you can still use 87-89. I would try something like gogriz said. There are tons of Zs in GA you could use, but i can never throw away Z parts. You could also number the parts as well and keep a sheet seperate to see what "lawn ornaments" (parts) the numbers are. Plus taking it apart helps you learn just that much more of the layout of the L motor. You will mess something up or break a bolt that you wish you did something different on (i still do all the time). So at that point its not a big loss and you can use the knowledge for a motor you get in GA. Definately worth a try! I may have rambled there for a second but i read it again and it at least made sense to me (not saying much)
so you do have a 280ZXT? With the 300zx ECU you need the MAF and the Dizzy internals. If you dont have the turbo motor, you need to switch out the oil pump drive shaft for a l28et one and then swap the internals. You also have to swap some wiring around, there are writeups. Your car is automatic? Do you like automatic? just wondering why your keeping it. (sorry i despise auto trannys) If your really wanting everything for this car, get ARP head bolts. Once fully torqued down, head bolts slightly warp, not giving you the same torque specs. Dont worry about intake manifold yet untill you get more into everything. Intake, downpipe and vacuum boost controller would be a good start. Oh and the rear end housing and gears is reffered to as the differential.
definately fix the crushed portion of the pipe and smooth out the transition from the flanges to the tubes! those things look rough in there. I'd think those insanely rough edges and "shelves" of transition in there would cause almost as much flow trouble as the crushes themselves. Besides that, $300 is not bad, even if u had to cut the whole thing up, the forming and bends themselves would cause u enough trouble to cost that. just to point out to the others here, the flash of the camera even cast a shadow of that rough edge towards the bottom end of the leftmost exhaust tube.
well you know what i mean. even though there are lots of different applications, sizes, shapes they list the same pressure drops through these. Im just wondering if anyone has one and has measured this or has some feedback on it.
Ebay intercooler These look good overall. Bar plate design, read reviews from guys that didn't know any technical stuff but said it worked great. I was wondering, anyone verified the pressure drop on these? They state .05kg/cm2 at 1.2kg/cm2 of boost (which is .72psi drop at 17.1psi)
from looking at all you've tested, the most likely reason for your car not starting is the cold start injector which is controlled by the thermotime switch. I spliced in a switched nine volt battery to mine because i was having the same problem. If Im not right, you've only wasted 15-20 minutes. Oh and do not pay 1500 for a L series motor unless it has an aftermarket rebuild or something (forged pistons etc) You can always find running motors for under few hundred if not free. For 1500 you could buy a red top sr20
i know the guy who runs bluegrass muffler. there is a slight chance if people want to buy a lot of them i can get them a little cheaper per unit.
Back-halveing a 240z purposely for drag
dj paul replied to MyLaDyZ's topic in Gen I & II Chevy V8 Tech Board
Unless your going to be putting more power down or you just want to do it just because it would be cool (i know ive done that) i would probobly use the stock R200 and maybe get upgraded half shafts. it would only be about $300 i think and way less work. Then if you break those, you could go ahead with the solid axle setup. The only other thing i could see is going ahead and spending the money to get a locker setup, since any quality locking setup for racing using the R200 carrier is over $800 anyways, i believe. If this is what your looking for though, you could always get a suburu rear end, you just change the output flanges and youve got a viscous locking diff for under $50. I can get back to you on what years and models this diff came on. -
i second just cutting the rust out and welding sheet metal. Thats the best route. I ordered totally new floor pans for my first Z and soon discovered i could have done the same thing with sheet metal after cutting them up so many times.
Car cranks, but won't start...
dj paul replied to justinr54321's topic in Trouble Shooting / General Engine
should be in the instructions for the dizzy you were ordering. If not, there are diagrams at autozone.com. I cant remember on mine because i ripped everything out. Set a hooked up spark plug on the valve cover, when you crank the engine it will spark. Also check and make sure if the ignition module (little black box on the side of dizzy) is grounded well. But if youve already taken off the new dizzy to go back to the points i guess just check the wiring at autozone. -
Jon's 2 year roll cage saga...
dj paul replied to JMortensen's topic in Brakes, Wheels, Suspension and Chassis
Sorry to not be clear. Im not saying there needs to be another bar here, that would be unnesassary to very little gain. Im talking about the shear horizontal load, i was in a hurry and didnt mean to word it like i did. the box you are talking about will do just fine, i was simply wondering if that portion of the cage had plans to change. By the way, the cage looks great if i didn't mention it before. -
Did you change this since this picture? i didnt get a chance to look through and see. I think i saw a picture where it was different but i cant remember. Im assuming your going to be running a bar perpindicular to this or something because this will not support the load of a rollover, it will just go right through the floor. Im pretty sure you know that, but i just wanted to be 100% Edit: I would place a decent thickness steel plate on the floor itself, and put a small piece of pipe to extend it to that plate, to spread out the load. Maybe even a piece of angled steel up against the floor and the rails. (cant remember the real name for them ATM)
