toolman
    16
Everything posted by toolman
  1. More pics Made part shelve to store the parts during the build as I have only a two car garage. The shelve is made of 3/4" plywood 48" X 43" supported by 2" X 4" boards anchor bolted to cement wall. Top shelve will hold hood, fenders, doors, hatch, and etc. Below the shelve the front and rear suspension parts will go.
  2. window cowling-no rust left lower door post-rust but repairable engine compartment right side lower inner front fender-rust but repairable cowling panel-no rust left lower hatch panel-rust but repairable
  3. Starting to strip down the car to check how the corrosion is. Sunny
  4. toolman
    P1030304
    From the album: PREMATURE RESTORATION
    Stripping the vehicle in proess
  5. toolman
    P1030303
    Window wiper section no rust
  6. toolman
    P1030302
    Window cowling
  7. toolman
    P1030301
    Window cowling no rust
  8. toolman
    P1030300
    <p>Another view of engine compartment</p>
  9. toolman
    P1030299
    <p>Engine compartment empty for now. Might install steel tubing inside old frame rails.<br /> Checking out Hoku kits and others. Might even cut firewall and set it back 4&quot; to 5&quot;. If I do that,<br /> a dash board might have to be constructed. My old dash is cracked and I wanted to try a new method to<br /> repair it.</p>
  10. toolman
    P1030297
    Since I only a two car garage I had to build a parts storage area. The shelve is about 48" X 43" out of 34" plywood. It is supported by 2" X 4" anchor bolted into cemete wall. Top shelve to hold hood, fenders, doors, hatch,etc. Bottom shelve for front and suspension parts.
  11. toolman
    P1030296
    Left side rocker panel? might need replacement have inspect better
  12. toolman
    P1030295
    Left side lower rear front fender rusted but repairable
  13. toolman
    P1030294
    Right side lower front fender rusted but reairable
  14. toolman
    P1030293
    Window cowl panel-top good
  15. toolman
    P1030292
    <p>Window cowl panel-bottom side good</p>
  16. toolman
    P1030291
    Left hatch hinge good
  17. toolman
    P1030290
    <p>Right side hatch hinge good</p>
  18. toolman
    P1030289
    Left rear lower hatch panel repairable
  19. toolman
    P1030288
    Right rear lower hatch panel repairable but need to replace center panel
  20. toolman
    P1030287
    Right side floor pan and subframe repairable
  21. toolman
    P1030286
    Right rear lower door post repairable but might need to replace rocker panel
  22. toolman
    P1030285
    Right side lower door post rusted but reairabe
  23. toolman
    P1030284
    Right side seat not bad but will be redone or replaced
  24. Thanks for the Good Luck!! No matter how well you plan something, luck can play an important part!! I am planning the completely strip out the Z and build a rotisserie to make it easier to do the floor panels. Stripping all of the factory undercoating also will easier than working under the car. My original choice of replacement motor was a Chevrolet small block 400 bored out .030 over with forged pistons with longer 5.6 con rods. balanced and Chevy Fast Burn aluminum heads. This motor was never run and was just sitting on a engine stand. I decided to sell this motor and purchase a new Chevrolet LS-3 crate motor instead. The LS3 will weigh about a 100 lbs less and be a even better platform for future endeavors. So I'll sell the 408 motor. I already found a T-56 speed transmission from a !ROC Camaro. My friend at the local machine shop save me a cracked LS block to use to mock up mounts. I'll pick it tomorrow. I have a R200 differential in the car and might run with it for awhile before upgrading that too. Please give me any suggestions to my build as I am sure I will run across some problem that I didn't plan for. Thank You in advance. Sunny
  25. From the album: PREMATURE RESTORATION
    <p><br /></p>
