toolman
    24
Everything posted by toolman
  1. toolman
    P1030328
    From the album: PREMATURE RESTORATION
    stripped out rear of car-interior panels,carpet,taillight assemblies,fuelntank and wiring harness
  2. toolman
    P1030320
    mounts for rotisserie -made of 3/16" mild flat steel and 1" x 1/8" square tubing
  3. toolman
    P1030319
    <br />
  4. toolman
    P1030323
    <p><br /></p>
  5. toolman
    P1030322
    <br />
  6. toolman
    P1030320
    Constructed two mounting brackets for mounting the rotisserie on front end.
  7. toolman
    P1030323
    Removed dashboard from car. As dash was cracked badly not sure to put a full dash cover on or build a complete new dash out of metal.
  8. Overall the body is not too bad and repairable. On the right side rocker panel might have be replaced on further inspection. I might even cut the firewall and move it back 4" to 5" for better weight distribution. Also might install square tubing into the frame rails and extend the rails to the rear cross member. Checking out Hoke and other mount guys. I wanted to try out a new method of repairing my cracked dashboard but it was too far gone, Anybody make replacements? Sunny
  9. hatch hinge-no rust right lower hatch rust but repairable left lower hatch-rust but repairable right side floor board and sub frame-rust but repairable hatch hinges-no rust right lower inner ender-rust but repairable right side seat-repairable but might repace
  10. More pics Made part shelve to store the parts during the build as I have only a two car garage. The shelve is made of 3/4" plywood 48" X 43" supported by 2" X 4" boards anchor bolted to cement wall. Top shelve will hold hood, fenders, doors, hatch, and etc. Below the shelve the front and rear suspension parts will go.
  11. window cowling-no rust left lower door post-rust but repairable engine compartment right side lower inner front fender-rust but repairable cowling panel-no rust left lower hatch panel-rust but repairable
  12. Starting to strip down the car to check how the corrosion is. Sunny
  13. toolman
    P1030304
    Stripping the vehicle in proess
  14. toolman
    P1030303
    Window wiper section no rust
  15. toolman
    P1030302
    Window cowling
  16. toolman
    P1030301
    Window cowling no rust
  17. toolman
    P1030300
    <p>Another view of engine compartment</p>
  18. toolman
    P1030299
    <p>Engine compartment empty for now. Might install steel tubing inside old frame rails.<br /> Checking out Hoku kits and others. Might even cut firewall and set it back 4&quot; to 5&quot;. If I do that,<br /> a dash board might have to be constructed. My old dash is cracked and I wanted to try a new method to<br /> repair it.</p>
  19. toolman
    P1030297
    Since I only a two car garage I had to build a parts storage area. The shelve is about 48" X 43" out of 34" plywood. It is supported by 2" X 4" anchor bolted into cemete wall. Top shelve to hold hood, fenders, doors, hatch,etc. Bottom shelve for front and suspension parts.
  20. toolman
    P1030296
    Left side rocker panel? might need replacement have inspect better
  21. toolman
    P1030295
    Left side lower rear front fender rusted but repairable
  22. toolman
    P1030294
    Right side lower front fender rusted but reairable
  23. toolman
    P1030293
    Window cowl panel-top good
