fast-datsun
Everything posted by fast-datsun
  1. Remember a header is for a NA car and a turbo manifold is for a TURBO car totally different.....so there could be some confusion on what you really want.....
  2. But the CAR is designed from scratch for that, A car designed for a 52% front will handle very different if the suppension is not adjusted for the change..
  3. THIS is moving the weight way forward; what is your front % 60% ????????????? will be difficult to street use like that ?????????????
  4. We have a 04 car and now a front clip and have started the mounting kit and other parts for the RB 350z swap....
  5. We have a 04 car and a 05 clip and have started the RB swap parts with SR and VK 45 and 56 upgrade to follow...
  6. YES see web site... www.mckinneymotorsports.com Mack
  7. Z31 kits on the web site now...
  8. when can we expect z31 rb kits?
  9. CALL ME FOR INFO 951-304-9300 MACK HERE RB26 PICTURES
  10. if you shop around you can up grade to air/hyd for a reasonable cost if your going to do alot of bending. its easier to hit you marks.
  11. JD2 is great I got one of the first ones and still use it here are carts I made to make it portable...
  12. We can build the kits for eather , if there is plenty of people intrestered......... Mack McKinney
  13. April 4th will be on the web site for the mounting kit next few day after that for the intercooler kit, radiator kit , down pipe, drive shaft and other parts.. first 4 people will be offered a 50 dallor refund for pictures and write up on their experance with the kit... Mack McKinney
  14. Are the injectors in good shape?? have they been cleaned and flowed, dirty injectors can lose as much as 30% of the orginal flow rate..which could be causing your lean readings... By you last plug check you should not be lean, if so the plugs would be white with some possible blistering on the cermaric..
  15. Will do...VH much easier than the VK, but will do both.....
  16. do you have any more of the caliper brakets, If so I woud like a set for my new car...
  17. RB25 swap parts almost done. see pictures..
  18. We have started on the swap kits for the Z32. We will be doing kit for the RB 20/25/26 the SR20DET, the VQ35, the VK 45/56 and the Chevy LS motors. Intrested parties email us at morepower@mckinneymotorsports.com for question or imputs for the swaps.. Mack
  19. We have started on the swap kits for the Z32. We will be doing kit for the RB 20/25/26 the SR20DET, the VQ35, the VK 45/56 and the Chevy LS motors. Intrested parties email us at morepower@mckinneymotorsports.com for question or imputs for the swaps.. Mack
  20. We have the RB and SR swap kit in work for the 350z/G35 right now expect release summer 2012; VK kit getting upgrades with latest change after feed back from Last years drift teams testing... Mack
  21. If you can supply the in quality and quanity I would intrested. Call me...Mack 951-304-9300/1045
  22. I need a straight 300ZX shell for R&D work, buy or rent ASAP in southern California (Murrieta) CHEAP!!!!!!!!!!!!! Mack McKinney
