fast-datsun
Everything posted by fast-datsun
  1. Yes after the 240SX and S30 70-78....Z cars first..
  2. any adapters for sale and pricing?????????????? MACK
  3. Latest project on the board.... VK56 will need new oil pan, trans adapters for both the VG and VQ35 trans and other changes to fit properly. Mack
  4. We can supply a modified one or do yours if you need...
  5. We can supply a modofoed one to do yours if you need...
  6. Thanks!! We know times are hard out there and $$$ is tight, we will do our best to help the Z-guys be able to make ther dreams/plans come true. Mack
  7. Working on a steel pan and a second supplier on the alum pan to see if we can get pricing down a little, BUT you get what you pay for QUAILTY craftmanship cost... Mack
  8. WE modify them for more fender inter panel clearance. Cut off flange and weld on at new angle....
  9. We offer a mounting kit for the FWD VQ motor other than mount position the engine are almost the same, you can install 350Z/G35 parts to up the HP or any aftermarket parts for the VQ You do have to swap intake system and oil pan to fit it in.......
  10. Going to be one BAD AXX car when your done, can't wait to see it done.......
  11. We have finally got the first production oil pans for the RB20/25/26 for sale.. There 7qt+ filter baffled, Pan rail in CNC'd 3/8" alum and body of the pan is 100/1000 alum comes with RB20/25 pick-up or RB26 pick-up and made for street and mild racing. For all out racing we will build you a pan to sute your needs DRAG, ROAD RACING, OR DRIFTING ECT.. We will offer head oil drain back fitting on the pan, external oil pick up recommonded on the RB26, and a DRY SUMP pan with pump, brackets and lines PANS ARE BUILT TO ORDER SO YOU CAN GET WHAT YOU NEED OR WANT..[/b PAN BASIC PRICE IS $800.00+ SHIPPING AND HANDLING, CALL FOR ALL OTHER INFO
  12. NEO is a puller clutch. Trans need to be from a turbo RB25 not the NA which is like a KA trans....
  13. will have to have them made or make your own..
  14. THE 283 will respond well to the GM Parts 30/30 Corvette cam with solid lifter or the HYD 327/350HP hyd cam for 60's Corvette from GM parts. with holley 650/750 and headers
  15. Wildcap no longer makes the adapter for the 300zx trans.. There are adapter for the VQ35de and the VQ35HR trans out there which we are going to test. We lookin into the 300zx adapter if there is intrest... Working on mounting kits for S13/S14 and Z cars..
  16. Did you ever get anytihng?????????????????????????????????????????????????????????????????????????????????????????????????
  17. The VQ30DET will not fit in with out major mods to the turbo system.... the crossover pipe runs behind the motor on top of the bellhousing...and turbo is on the drivers side hanging low so it also has to be moved....
  18. There are actually 3 types of crossemmbers 69-73 early late 73-76 and 77 up.... we can sell you just the trans crossmember(mount) if that what you need
  19. BOB WAS ONE OF THE ORGINAL DATSUN TEAM WAY BACK WHEN... You probably have heard that Bob passed away on June 9, at the Sharp Hospice Care facility surrounded by his family. The following information has been requested.... The memorial service will be on June 25 at 11 am, at the Church at Rancho Bernardo, 11740 Bernardo Plaza Ct., San Diego, Ca 92128. Take I 15 to Rancho Bernardo Rd, exit East one block, turn right at Arco station, go one block, turn right on Bernardo Plaza court, go one block to church on right. In lieu of flowers, donations in memory of Bob would be appreciated to Sharp Hospice Care, Grossmont Hospital Foundation, PO Box 158, La Mesa, Ca. 91944-9942....or charity of your choice. Thank you from our family.
  20. Did you ever make any for sale????????? IF SO HOW MUCH????? 951-304-9300 MACK
  21. The orgiinal company we hired to do this for us flaked out so we are doing it on our own. Will keep you up dated. we doing harness and computers.
  22. What parts (custom) that is not out there with good quality would you all like to see??????
  23. Our radaitors are custom made for us with the correct size inlet and outlet, so you can use Skyline hoses and already have brackets installed and you can get custom fan (3200 CFM) and shrould if you want..
