fast-datsun
Everything posted by fast-datsun
  1. we have a dual pass crossflow for the RB as wells as several others....
  2. Will you wholesale them at 2-3 at a time???????????? 951-304-9300
  3. we have made changes to our mounts so both the RB and SR mounts should fit right or left hand drive cars. New SR20 6spd crossmember in work....RB /300zx trans mount and shifter in testing...for sale soon...
  4. We made the changes to the mounts so they will work with right or left hand steering.... looking for right hand drive car owner for testing.....
  5. We have the rb/300 trans conversion shifter and plates and crossmembers for the trans almost ready to sell.......
  6. Color of wires may or may not match you chart, always use pin out, pin number and usage and you will not make a mistake!!!!!!! Nissan sometime changes colors and uses a color(s) more than once ,,,,,,,,
  7. Mounts shipped. Sorry getting set up for wire transfer with current banking problems, has been time eater....
  8. R33 came with the the single (rb25 style pump) and most R32 had the dual port pump....
  9. we use the Z32 cover to convert the R34 from puller to pusher clutch....
  10. Looking good Kevin !!!!!!!!!!!!!! Call me on howw the testing is going...
  11. WE have a mount kit for the FWD VQ35 motor into the z car.....Mack
  12. NO.... to make it fit a RB20/25 in the Z you going to have to do cutting and welding...and adding to make it fit..as its designed for the SR20 into the S13/14 chassis...
  13. Call me at 951-304-9300,, oil pan is 1/2 in from the rack...as low as you can go...
  14. I will try to call this week and get info for our R&D work for the 5.6 and 3.5 motors... mack
  15. Thats good because I do not like the electric throttle....Mack
  16. Our kits for the RB are done, the include engine block adapter(2) motor mounts POLY (2) Trans crossmember and POLY trans mount. We have down pipes, intercooler kits with alun piping, Full 3" exhaust. radiator, wiring conversions. We have our VQ35 swap kit almost done for both the 340z/G35 and the Maxima engines. SR20DET mount kits, intercooler kits, down pipes, exhaust, done and ready to go....
  17. made fron DIcon...Thanks for the info....
  18. when are you looking to buy ?? Call me Mack
  19. gear box are rated in Torque and HP not boost. RB25 and RB26AWD share the same gears and shafts except the out put shaft also the 300ZXTT gear box Has same gears and similar layout...
  20. it make no problems at all.. the gear box will stll be bolted on fine....
  21. What about a set up for the VQ35 motors?????????
