Greg SmileZ
Everything posted by Greg SmileZ
Found one on Craig's list.....I need a replacement bolt that the brake and clutch pedals pivot on in the pedal assembly of my 1977 280z. I believe the bolt from either an auto or stick pedal assembly will work. Thanks - Greg
"nice and close" is not the way to go....I don't recall exactly what the rule of thumb is, but the fan should be about 1/2 inside the shroud, and 1/2 outside the shroud. Do some searching on what is the correct position. I fabricated my own shroud out of aluminum. See below. http://forums.hybridz.org/uploads/500/DSC01337.JPG
Repair estimate - Auto Transporter nightmare
Greg SmileZ replied to mchong75's topic in Body Kits & Paint
A buddy of mine just had his 240Z body work done, and painted at All Z. Great Work! I would not hesitate using them. They know Z's, and will do a good job for you. -
Abbott X Speedo Question
Greg SmileZ replied to Vette Powered's topic in Gen I & II Chevy V8 Tech Board
I've been using the Abbott converter with my T56 for about 6 years. It's worked just fine. I use the stock speedo....just depends on which way you want to go! -
Has anyone purchased a starter from DB Electric? They advertise AC Delco / GM type starters like # 7 in the JTR manual (page 3-5) Heavy duty gear reduction starter used on the 1993-1997 V8 Camaros and 1994-1996 LT1 350 Caprice, for a 153 tooth flywheel/flexplate. They are China knock-offs. They sell them for about $60 with the real deal costing more than $200. Just wonder if anyone has purchased one and had any experience with them. Generally I feel if the price is too good, there must be something wrong. PS - I'm starting my second swap of a 350 into a 1978 Z....
Get and read the JTR manual, get a shop manual and start studying, then read JTR again and again and make the decisions for yourself...It's all there. If you are going to be successful in swapping an engine, you will need to do research and understand what and why you are doing all aspects of the swap. Good luck....
JTR Raditor w/ fan and shroud for sale
Greg SmileZ replied to 240hoke's topic in Gen I & II Chevy V8 Tech Board
Different approach. Mechanical fan, pop rivets instead of welded. Ron Davis aluminum radiator. Hope this help you decide what way you want to go. Greg -
I have a '77 280Z with a 350. In my manual it says (and I believe what I purchased and used from JTR in 1999) is 5/16" setback plates, 2 1/2 and 1 1/4 spacers for motor mount and 1/2 x member spacers. So....1 1/4 instead of your 1 1/2. 1 1/4 worked fine, don't know why 1 1/2 would not work either....Greg
FYI - I purchased my JTR manual in 1999 and it is also a 7th edition. I think the more important item is the printing month and year that is on the inside title page. Mine is dated June 1998. I suspect that those who are buying their manual now have a much more recent date. Just my 2 cents.....
Anyone want to sell JTR manual?
Greg SmileZ replied to Buckv8240's topic in Gen I & II Chevy V8 Tech Board
Just me, it will be the best $40.00 you will ever spend. I've read it cover to cover at least 4 or 5 times, and then sections over and over. You will not be sorry you purchased it.... Do yourself a favor and purchase it. Speaking from experience...... -
Who swaps their engines by themselves?
Greg SmileZ replied to Plague_oc's topic in Gen I & II Chevy V8 Tech Board
My 350 into my '77 280Z was my first swap (I'm 50ish, but working on cars all my life). I agree with everything above, except I did not need a welder. For the couple things I needed welded, I had a friend with a welder do them for me. I could not justify the cost of the welder. The lift, JTR book, basic tools, a plan, budget and a realistic time table are all very important. -
That's what I did too. By far the cleanest way to go, and I think the easiest!
Is the Chevy V8 forum a catch all for every question or comment no matter if it is Chevy related or not? I know that it gets the most views and therefore the most responses, but....Seems I've seen the Chevy V8 forum degrade over the last several years.....transmission comments, and everything else. Sorry for the negative comments but at one time it seems like members cared where they posted their questions and comments. Thanks....
Edelbrock Carb Help - Mike Kelly
Greg SmileZ replied to v80z's topic in Gen I & II Chevy V8 Tech Board
Try this link to a manual for your 1411.... http://www.edelbrock.com/automotive/eps_intro.html#contents Good luck, Greg -
I used a 7/8" with my T-56. I've purchased a 3/4" and think (based on my calculations) that it will be the right diameter and give me the proper pedal feel and movement....just my 2 cents. Welcome....
Do you have an answer to the question about having the motor/wipers stop at the bottom of the windshield? Thanks, Greg
I've read many different websites describing the "best" location for Temp sensor for an electric fan. Some say intake manifold, some say inlet side of the radiator, and others say the outlet of the radiator. Seems to me on the intake manifold the water would never get cool enough to have the fan switch off (assuming a switch that turns on at 195 and off at 180. Comments, suggestions or experience Thanks!
T56 clutch master question.
Greg SmileZ replied to GB300Z's topic in Gen III & IV Chevy V8Z Tech Board
With my T-56 (in a '77 Z) I used a 7/8" but plan to go to a 13/16". The 7/8" is a pretty stiff (too stiff for my liking) clutch pedal. I think the 1 1/8" will be way too stiff (to the point of putting alot of excess strain on the firewill where the master cylinder mounts)....just my 2 cents. Greg -
Link does not seem to work...here is a different link to the T-56 service manual. http://www.ttcautomotive.com/English/onlineorder/pdf/LD56-0610-0199.pdf Greg
I just wonder why some people pay so much for Z stuff on eBay? There is a Foot Rest Pedal Pad listed, and the bidding is up to $20.50. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7940980331&category=6763 You can buy a complete set (all 4) of new pedal pads at a dealer (Courtesy Nissan here in Dallas, and they list them on their website) for about $15.00! Dealers still can get alot of parts for the Z. I guess the message here, is check with your dealer before you buy parts on eBay for way too much! .....Greg SmileZ
JTR radiator and Taurus fan fitment.
Greg SmileZ replied to DaleMX's topic in Gen I & II Chevy V8 Tech Board
I have spoken to both brothers at one time or another over the past several years. All I can say is that if either one has a personality problem (I assume you are referring to Mike), that I wish everyone had that personality problem. Both have been more than helpful, bending over backwards to help me with my questions. I wish all businesses had the personality problem that MikeJTR is talking about!!! Mike even went to the extent of sending me a book that we were discussing for FREE! Long live JTR….send them your business! Greg -
Spotfitz, I've also been looking at the Too Intense headlights, along with Motorsports....I'm heading to CA in a couple weeks, and plan to visit both Too Intense, and Motorsports to look at their products. I'll let you know what I see/find out.... Greg
I've searched and don't see any discussion here of the various headlights that will work with Zs....I have a 1977 280Z. I've converted my headlight wiring harness to use a relay, but now I want to upgrade the headlights. Has anyone purchased any of the headlights or headlight kits from: Anyone on eBay? Too Intense Restoration? H4 Lights? Motorsport Auto (zcarparts.com) Victoria British? Comments about any of them, good, bad, expensive, cheap, etc? Thanks - Greg
