BallZ
  • Gender
    Not Telling
  • Location
    Sanford NC
BallZ's Achievements
Newbie
  • Conversation Starter Rare
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
0
  1. I'm going to be swapping in the 8.8 diff, and this kit uses axles from a Porsche 930. I'm not against spending the couple hundred $ for them but if anyone happens to have the blueprints/specs that they'd like to share that'd be awesome. I could save myself a few bucks by machining them myself.
  2. Hybridz used to bump looks like some of you older members finally ran everybody off...lol search newbs
  3. Looking for a 78 manual pedal box with pedals. Thanks
  4. This is a common issue with rb motors they're not actually made to be bounced off the rev limiter. Who knows how your engine was treated before you got it. Anyway this isn't a nissan issue it's a driver issue, there racing team figured this out long ago. It's actually a recommended upgrade for those that like to rev the piss out of the engine. Anyway thanks for the reminder better upgrade mine before I finish my swap
  5. Head over to your local fastenal they will have it
  6. I just read all 11 pages...anybody do the neo rb25det I just ordered it yesterday. Is there any differences I should be concerned about. I tried using the search but the crappy search will not recognize 3 letter words such as neo...
  7. Just to clarify its the front welded piece that goes over to the trans tunnel. Thanks for the reply
  8. Not sure of the year of the seats, with that being said the measurements work width wise, but my hold up is the front bracket welded to the floor. Would I be ok cutting the welded front floor mounting piece out? or do I risk other problem's by doing this? Thank for the insight tried searching for awhile but came up with way to many results...Ryan
  9. YOU MAY HAVE EXCESS AIR ENTERING THE INTAKE SOMEWHERE!!! Connect your AFM, have a friend start the car, you manipulate the AFM by hand it should run but you will have lean back fires. The same thing happened to me at first I was thinking that when I replaced my intake/exhaust gasket that I screwed it up. After trying the procedure I listed above, low and behold I missed a huge vacuum port that was hiding between the 5th and 6th runner. Also You can take the time to spray carb cleaner around your intake manifold and listen for changes in your idle...Ryan
  10. I had this same issue...found a huge vacuum leak on the intake. unmetered air can cause your problem
  11. ok, the only place I found that can do it said it would be approx. 125 give or take a couple bucks. Let me know what you would like to do. Sorry it took so long the military sometimes takes up all my time.......Ryan
  12. Hey I have not forgot about you, crap has gotten a little out of hand at work. I will have some info for you today.....Ryan
  13. I have no idea what shippiing would be, I can get you a estimate. How would you want it shipped? Not sure about a Gas Tank shop but I can call around. I know I can atleast get it hot tanked at a radiator repair shop, it will still need resealed. I will call around today and see what I can find out......Ryan
  14. I have a tank from a 76 280z looking to get $200 plus shipping. There is minor surface rust but its a solid tank......Ryan
  15. It looks like a Black Pearl and a decent price, if its not rusted out! Black pearl
