Posts posted by datman
Simon, you wasn't suppose to say anything! lol
lol sorry
You mean -8 on the feed and -6 on the return?
Or are you using a surge tank?
Yes on the feed (low pressure side) .I run 2 pumps so i have -8 from the pick up of the main tank into the walboro 255 pump then into the swirl pot, -8 from the swirl pot to the bosch 044 pump....then -6 to the fuel rail. The return is also -6 which tee's into the return from the swirl pot back to the main tank.
I have some Euro combo switches listing soon
Good Luck on the sale Simon!
Thanks Clive....could do with a little of that right now....
Everydody who poo-pooed turbos because 'they have non-linear power output' without 'low end power' really got taken aback when they went for a ride in the old Shark Car.
It's all how you set it up. Turbos don't have to come 'on boost' at 4000+ rpms. And if the do come on early, there's no reason they need to be 'out of breath' by 6000 either.
It's all old wive's tales perpetuated on the internet by people 'reading' a far bit more than they are actually 'doing'!
Amen!
I was thinking about this the other day...none of the wires in the cable from the megasquirt to the relay board are shielded....injector drive wires mixed with the pip and saw can't be good.
I run a Walbro 255 from the main tank via -8an to a swirl pot and a bosch 044 pump to feed the high pressure side. I run the return from the fuel rail back to a T fitting with the return from the swirl pot and back into the main tank...works a treat.
Here are the lights I have of my parts car, Lenses are in great shape but the chrome is not so good....I guess you could get this plated or replace with a US spec light chrome section.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270253073034
I bought a pipe kit from ebay....the alloy pipes came in various lengths and bends . The hoses were poor though and burst above 10psi. Still the pipe was worth the money, I just bought some samco hoses and better clamps at a later date.
mine hits its max VE number around 4100rpm ve numbers tails off after that...thats where my max torque is i guess
I think the red ones look better...but then orange is common here. I have a spare euro set I will stick on ebay this weekend.
I was just thinking along these lines...do you need to change the injectors to use LPG? I guess you would need to remap the fuel table to match the LPG calorific (is that the right word?) and octane value. I would imagine controlling the gas pressure for a high powered engine is the problem.
Golf and corrado G60 engine cars have dual throttle body that has a boost bypass for the supercharger under part throttle. I think Audi used a similar one. http://is.rely.net/2-1060-10033-l-7DMh3VLglsSHH21l0EtA.jpg
The bracket on the compressor housing will have to be cut off it you plan on using it on your datsun as you need to spin the housing round to get the outlet in the right place. I made a bracket bolted to the inlet manifold to hold the wastegate actuator.
The holset actuator is the wrong rate for use on a Z engine, you need to buy one with a lower psi spring. Like this http://www.verociousmotorsports.com/Shop-by-Category/Wastegates/Turbonetics-Dual-Port-Actuator-7-5-psi
this way you can have a low boost level or preload it by adjusting the threaded connector on the rod.
Ok checked this again today, I have 175PSI give or take 2PSI on each cylinder. Seems like a better figure.
I have had problems with an electric fan mounted too close to the VR (crank) sensor. Caused all sorts of input trigger errors, causing the engine to miss. Moved it away from the sensor, problem fixed.
Pete
Yep, me too!
How about the Air flow sensor? maybe the ECU is running on a pre prgrammed fuel table until it gets all the info it needs from the sensors then once its switches over its getting bad readings from the MAF . Could even be a dirty track on the TPS?
this may help:
http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf
Does he have a crank sensor? if not check engine and body grounds are good.
those cars don't even look that rusty, Man you guys are spoilt for choice!
What are the common misnomers ppl use?
in Non Tech Board
Posted
Over here so many people say "I was led in bed" I can't stand that one.
