philfree
Everything posted by philfree
Hi yer i thought of the ford 4l dohc turbo they make some realy cool hp their is a gguy over here putting one his 240 with i think the 6 speed auto for those who havent drive the zf 6 speed their awesome but they run into the problem of the motor being quite tall and i don't want the bonet to be modified if i can help it. the reason i thought of the valiant is my mate used to be right into them and has the gear to turn a normal 265 into a upgraded 6 pack and being that the lean over it should be easer to fit under the bonnet and if i use the base 265 their hp is similar to the l motor so getting it road legal should be much easer up here in qld.
Hi I sold my z a while ago because i was forced to but have always wanted another one i planed on the ls1 conversion but i had suggested to me today that i use a 265 valliant motor. With the right modifications they can have some real go while still being a inline 6cyl the only real problem i can think of is that it might be to tall ie wont fit under the bonnet what does everyone think
Hi i used the 93 commodore motor witch i believe is the series 2 with the top radiator hose at the front of the motor, was running the turbo 700 gearbox, standard ecu which was pretty easy to install are you guys interested in pics?? i don't have many tho
I used to have the NA 3800 in my 260z 2+2 no one realized it had the v6 until it was to late they all assumed it was a "crappy old datsun" Holden here make a sc version of the "ecotec" v6. I would of liked to swap that into the z. But i think it would have clearance problems with the bonnet given that the fan off the alternator (on the NA version) chopped through the bonnet lineing and the sc version if alot higher motor.
Ford Falcon Turbo I6 - Aussie donor
philfree replied to LuciferDarklord's topic in 6 Cylinder Z Forums
i agree with all said above except i think the na motors have more power ba - 182fwkw's bf - 190 fwkw's fg - 195fwkw's if any one is interested im willing to help people out with parts from aus if they need them -
hi I know they are a double over head cam and the bf -fg's have variable cam timing the heads apparently flow extremely well because their "cnc ported from the factory"?? i know a fella with the bf version and with new plenum, intercooler, intercooler piping , relocated filter, exhaust , fuel pump, injectors and tune his car does constant low 11 sec 1/4 mile passes in a 2000kg body -
ford have brought out the new fg f6 Typhoon now witch is a 310kw from the factory and a 270kw version for the fg xr6t. the fg f6 has been proven to make over 350rwkw's with just a k & n panel filter, exhaust and a edit link to new fg range http://www.drive.com.au/Editorial/MiniSite/MiniSiteArticleDetail.aspx?ArticleID=52523&vf=28&MiniSiteID=8 -
Wacky electrical problem now my car wont start help!
philfree replied to bassan's topic in Trouble Shooting / General Engine
Hi can you give me a little more info about why you bridged the voltage meter ... the warning light needs to go from ignition through a bulb like a 5w or something to the warning light output on the alternator thanks -
Hi whats happning here is you should have a main battery positive that you have got hooked up but have you hooked up the warning light this bring the alternator onto chargeing alot quicker other wise it needs alot of revs to self excite as they call it so is the warning light hooked up?? thanks -
great!! so is it running now? -
Hi first off if you battery terminal is "sizzling" then it's got a very bad connection that would be my first port of call make sure both terminals are clean and not able to be twisted on the post of the battery by hand. the click with the starter every now and then will be a few things connection between starter, the starter it's self of the ignition barrel not providing enough amps to trigger the starter motor. thanks -
Hi first thing i would look at is check all the fuses and fusible links check the plugs and earths for the headlights. Have you checked the switches for the doors they can play up with bad contacts etc
Hi I am not trying to drag this on. But i went into the local Nissan dealer today to check the engine number and vin number. Seems its not on their system so they have told me with reasonably high certainty that the car is imported. this is where i am lost. I have a 79 so its one of the early ones with a f54 block and a p90 head and 3speed auto. did this combination ever come out of a factory like this? Also can you tell if the pistons are dished or flat top by taking the plugs out? Thanks Any help much apreciated
Hi Yes i would really like it to be but it's a 1979 and ive been told Nissan never sold turbo 280zxt's in Australia also it's not turbo.... this could explain why it's running rich consistently because of the na computer and the turbo injectors Thanks Philfree
Hi So the head has been switched right? how do i tell if it's had a whole motor swap or a only a head swap if it's had a motor swap it would have a turbo motor right? Thanks Philfree
Hi I took a pic of the number it's a a bit hard to read as i used my phone but it's a p80 in my book link: http://philfree.250free.com/p80.jpg Thanks philfree
Hi I found out that i have a f54 block with p80 head. Is this right i can't find any documentation on the p80 does anyone have any information. Thanks Philfree
Hi Thanks for the replies. I have asked the seller a question whether the manifold has had anything else done to it apart form the tb. One this i though of just now will the stock computer be able to uses the sensors on the tb? Thanks for help very much appreciated
Hi I was having a look on ebay today and come across this intake. I have a stock auto, 79, 280zx would it be worth buying this manifold and putting it on? would it give me any more performance? Link here Thanks any help appreciated
Hi Thanks for the help. I may post my results depending on weather someone wants the information or not. So please post or pm if you want to know the results Thanks much appreciated
Hi sorry for the late reply i was away for a few days. I don't know about the input flanges. But i have been down and seen the guy (it's at the local wrecker) and he will sell me the whole car minus alternator, front wheels, and front bumper for $200AUD so ill more or less have the whole car. So now i can get the whole car what i would like to know do i need anything else will all the parts form this car be enough to convert my 280zx to manual? Thanks for the help Much appreciated
Hi Thank you for your help I don't know how many skylines came out with the l24 but this skyline did i double checked the year and it's a 1982 with l24e motor i already have the alternator off of this car to replace the one on my 280zx. having said that would i still need a custom drive shaft and custom mounts? Sorry i didn't mention/ make it clearer in the first post Thanks any help appreciated
Hi I only just brought my s130 last week. Which is a 1979 na 280zx 2+2 auto i have come across a 2.4e 5 speed manual skyline which i think is 1985 (will be checking in the next few days) my question is how much work is it to fit the gearbox into my 280zx. That is all the information i have on the skyline please let me know if you need more information. Thanks Any help much appreciated
Hi I got a 75 260z 2+2 4 speed auto with 3.8l commodore motor the computer for it is hopeless
