Wedge
Everything posted by Wedge
  1. If you can put some inside the rear holes behind the seats like we see on picture 2 and everywhere you see rust it will prevent further damage .
  2. Be carefull when you remove the steel flap tab because theirs a bearing at the end of a spri ng so it could (stay on like my rb ) or fall inside the tranny ( like my z32 box) it fell in the drain pan so i had to fetch it . I still need to find the torque spec ,ill post them when I find them
  3. Its all done just need a new front cover gasket and to torque everything down and thats it .
  4. I went back to the garage and that was it ! Thank you all and specially you Mr Soileau
  5. From what I red in the sticky their are 2 dowel pins to remove . At first when I removed the front plate and the 2 snap ring i taped on the bellhousing and it wasnt coming off completely then I went back to the computer to check the sticky and thats when i saw the dowel pin . I went back to the garage and checked the shifter rod to find it had moved forward the same length of what I had the housing off ,so about 3/4 inch . I tried to removed the pin I circled but nothing seems to do the tric. BTW Its rb26 bell going to be on a z32 of course .
  6. Here's a picture hope someone can help me on that .
  7. Hi, I am in the process of removing my RB26 and Z32 tranny bellhousing and I cant seem to be able to remove the shifter rod on my RB26 tranny . How do you remove the dowel pin mine looks like a cylinder with another smaller cylinder inside it i tried tapping on the middle one with a punch but it wont budge . Any ideas on how to do it . I cant post pictures now but tomorow I will to help clarify if anyone knows what im talking about. Thank you
  8. Wow you really are the King of custom RB26Z the one we all look up to ! I bow before you
  9. Personnaly i chose the RB26 over the SR20 because i wanted torque and because im a sucker for the I6 sound . But if i was to choose a 4 banger it would be a KA for the torque and cheapness of it .
  10. Thanks alot for the clarifications and picture everyone I guess I was being misinformed about the need to stitch weld the hole thing for a street driven 380-400hp RB 280Z . I will however do the shock towers and TC box . Thanks again .
  11. ^ Thanks for the advice Boy from OZ,so you just welded everything I outlined except front radiatior supports and the frame rails .In your first picture I dont recognize where this is on the Z it looks like the frame rails but im not sure . The reason why im doing this is beause I was told by a Z guy I met that the RB26 swap im doing would absolutly need some reinforcements to prevent twisting of the front end ... I am a little doubtfull since V8 guys dont seem to be doing seam welding but I told myself what the heck it doesnt hurt to make it more rigid .Since the car will be street driven 90% of its time ,their is no race track within 300km for my place, their is no need to go overkill either. And Tony D can you show me a picture or just a simple drawing of what you are talking about the C channel from floor to firewall .
  12. Thanks Tony D , finally the machine we rented didnt work out it was gas powered SMAW machine and the power was alternating to much so it stuck the rod or it burnt through . On 1/16 steel plate it worked nice but on the datsuns 1/32 it didnt . Ill have to get a MIG next time .
  13. Thank you very much John ! I'll post pictures of the finish product
  14. Hi guys just wanting to make sure that i have this right I made some red lines where im going to be seam welding the front . Please let me know if their are places where i should not weld and if their are places i forgot thank you
  15. I hear mostly that people aare running GT28RS-5 on stock plumbing and make great power in the 500-600 hp range . Personnaly i run twin GT28RS-7 wich are equivalent to a R34 N1 GTR turbo good to 500 hp range with stock like reponse .
  16. Me too I have error 500 showing up last night
  17. Wedge
    From the album: My Zed
  18. Wedge
    Front shot
  19. Wedge
    The Z the day after I got it .
  20. Ok then stitch weld it is ! But one thing for sure ill use glue for my rockers when im going to change them . Thanks guys
  21. Im going to say like theBrit install some overfendres and be done with it less problems in the long run .
  22. I get your point about fatigue in the metal if you pry it but then how would someone remove the sealant if they want to stitch weld the shock towers if not by prying it open remove the stuff the reweld ? I guess you could drill out the spot weld then remove the shock tower clean everything up then reinstall reweld .
  23. Hi everyone I was wondering if anyone heard or used 3M body panel adhesive on their cars ? I am asking this because I am wondering if it could be used as a chassis reinforcement instead of spot welding the intire engine bay . Shock towers,frame rail,fire wall etc I would just open up the overlaped sheet metal then clean the sealer and then glue . Would it be as good or better then spot welds ? I know for sure it would reduce creaks and crack sounds for the car but would it reinforce it or not ? Thank you .
