Rollins240z
Everything posted by Rollins240z
I searched and need some help changing my speedometer gear. 280z 5 speed. 300zx turbo clsd 3.7 diff So I bought an 18 tooth “blue” speedo gear to match the ratio of my diff for an accurate speedometer reading. I went to change it out and install new O rings and pulled out a purple 21 tooth gear. The teeth part of the 21 teeth purple gear is larger in diameter than the blue 18 tooth gear I’m trying to swap out. I did some research and my understanding is that the 20-23 teeth speedo gears use a different housing for the correct angle of the larger sized tooth gear offset. Here is the link http://www.classiczcars.com/applications/core/interface/file/attachment.php?id=1652 The 18 tooth gear shaft fits my housing perfectly, the only difference is the number of teeth and the diameter of the teeth. Do I need a different housing for my 18 tooth gear or am I ok? Z is not running so I can’t test it yet. I also read somewhere that the housing can be turned slightly to accommodate the smaller gear teeth size.
Confirmed s30 strut tubes. I measured the top inside spindle flange to the strut tube and I have a 3/16 difference. The left side is 15/16 and the right is 1 1/8" . I have welded in camber plates. As much as I want to ignore this, I didn't realize that it makes as much of 1" impact at the top. Having one side of my camber plates maxed out kinda eliminates the reason for having them in the first place. Crap!! Last night I ordered 2 angle meters from eBay. I haven't test fitted brakes on again yet but I did a while back and don't recall anything funky. I guess the next step is to start comparing other people's struts and eliminate the bad guy. Thank you everyone for the advice!
Thanks Pete! Ok just swapped hubs with same results. No visible damaged at tube/spindle, I sandblasted and powder coated these myself and did not notice any damage at that time either. The shocks slid into the tubes ok. Used a straight and could not see any visible bend. I'll try to find an angle finder and try that. Am I overreacting or is 1/4" difference a big enough deal to be concerned about? Thanks, Ryan
Hi all. Finally bolting on all drivetrain after a ground up restoration. I have a 1/4" difference between the top of my front brake rotors to the strut housings. Below are some pics to clarify the measurement location. Is this common on 240z? Will this affect my alignment ( I do have camber plates). If it is a bent strut housing how can I tell which one is bent? I did remove my Hubs and re-checked bearings/races. This car has not been driven in 20+ years. 1972 240z with Arizona z car hubs/rotors. Thanks!!
I have a brand new never installed MS-II 3.0 Setup. pm me your email and I will send you a bunch of pictures. Ryan
Make sure you don't use black primer. Primer is not a sealant and your car will eventually rust from the inside out. A product called "hot rod black" or similar is a single stage urethane paint and will achieve the flat black look you want. Just my 2 cents.
If I wasnt 6'4" --- The chopping the roof would be sweet !!! LOL
If you email modernmotorsports they will send you a pdf write up w/ pictures that do an awesome job of walking you thru the steps. You will need a small bearing puller and a snap-ring remover tool. Good luck.
IMO, The only way to go is welding. take sheet metal, cut it, shape it, then mig weld it. Be very careful that you take your time when welding. You can easily warp the metal if you get the area to HOT because it is so thin. Grind down the welds a little, and then use filler/bondo to smooth things out. Make sure to block out the body work and try to finish your body work w/ 180grit. I would wait about a week or so after primer before painting to allow for body work shrinkage, so sand scratches and waves dont show thru the paint. Anyways -- good luck, this is the way to go if you want it to last and look good.
Aeromotive has a great line of pumps & regulators. I have the A1000, cost about $300, little bit more expensive than the holley, I love it.
Wire brush attachment to drill is the best method, and yes it is very slow. I have found no easy way, undercoating is a pain in the a**. They do sell an air tool that works well if you have a big enough compressor. They use it at body shops called an "eraser wheel" to remove sticky tape and decals, you can put a wire brush attachment on it for undercoating. Anyways, good luck
I manage a big Shop in Northern California -- 1 1/2 North of Sacramento We are not cheap but we guarantee paint for life, you will not be dissapointed. Ask for Ryan Collins --- Concours Elite Collision Center, Chico CA 2267 Esplanade, Chico CA 95926 530-891-0234
I agree w/ teamnissan, just trying to repair one single rock chip or a door ding on a candy/3-stage paint job is near impossible. Too many variable are involved (air pressure, temp, spray distance, coats, toners) to execute an exact color match. It would sure look pretty tho. RC
how to draw the Z's body in cad...pics.
Rollins240z replied to OlderThanMe's topic in Body Kits & Paint
I like it. Looks so REAL!!!!!!!!! -
Do you have any pics?? Just curious of what the final product looks like??
What size rims and tires are you running. They look good under that beast. RC
Good job! Are you going to sand and polish it?? If you have 3-4 good coats of clear, you should be able to wet sand it with a block 800grit, then 1000, then 1500. It will get rid of all the dirt specs and the orange peel. Wet sanding especially with a block (stick or soft block) is pretty easy, just very time consuming (be careful of burning through on body lines). Buffing and polishing is a lot harder especially when trying to remove swirls. Good Luck RC
Do not use an eraser wheel with an air grinder. I did this a few years back and the eraser wheel came apart at like a 100mph and almost took my face out. They make a special air tool that rotates at a lower rpm or adjust your air pressure. Other than that, they work great for stripe tape and double sided tape from mldgs. Just my 2 cents.
Paint question regarding doors on car when painting?
Rollins240z replied to wickiewicked240z's topic in Body Kits & Paint
I agree with racerx. You also want to consider the risk of chipping edges if you paint parts off the car. It is terrible when every panel looks beautiful, but when you go to install a door you accidently chip the edge of the door with the fender. Then your back to square one. If you do this make sure the paint has a few days to cure, then tape all the edges and be very very careful during re-assy. I would pre-fit everything so all of your gaps are where you want them, then only take off the doors, hatch, and hood. The fenders should not get in the way of any jambs. Good luck RC -
Good original idea. Looks like a hybidz for sure. Looks great!. RC
Was it a wool pad or a foam pad? What color was it? I know there are a lot of different options on what type of pad you are using for different levels of cutting or polishing. Do you have any swirls. Thanks --- Ryan
