Ok, I see you are getting an RPM signal. There are a couple changes you need to make, however. Set the cranking trigger to Calculated first - setting it to Trigger Rise isn't going to work with a 103 degree trigger angle. (Most installations also need ignition input capture set to Falling Edge.) Change that first, then check if your injector outputs work on a Stim.
