Thanks Chris I got them last night , beautifull machine work ! question about position of pieces on drivers side , the way you have them in your pic with the plate against the block will it interfere with anything else ? I saw in the JTR book in chapter 3 page 10 they show a mockup using the set back plate against the block and the spacer between the set back plate and the crossmember motor mount... pretty much how you had them arranged in the pic, but in the writen part they talk about triming the chevy motor mount to make it fit but that's if the spacer is sandwiched between the block and the plate which then puts the chevy mount on the plate and right next to the bolts that go through the plate into the block , so if I put the plate against the block I wont neet to trim the mount but if I put the spacer against the block I will need to trim the mount,any problems doing this ? Thanks again for the beautifull pieces .
