Everything posted by rbpowered280z
^^^ looks good man! you should make some plates for the end of the dash or something, just to finish it off. if not, still looks good! Lloyd
a bit overpriced, i agree. but man, that kool koat is amazing i must say. super even coatings, no clogging, no chunking. best gun ive used! sick job btw, absolutely awsome! when i get a bigger oven, im going to be doing alot of valve covers i keep having to turn away. black mirror chrome ftw!
quick question why did you decide to run the fuel line through the cabin, and how in the world does any sanctioned racing body allow you to race with that setup? and also, with the fuel lines sitting on top of the cell, where is the rear bulkhead thats supposed to be there? Lloyd
hm, ok, i will be doing some more research and digging around. anyone have anymore suggestions for carbon fiber body pieces or fiberglass? i found smoothline, reaction research, showcars-body parts, zforceproductions. it seems like its ~6-700 for a pair of fg doors. pretty good deal. anyone have experience using them with manual window cranks or lexan glass? Lloyd
its worth a shot. anyone know what im talking about? i am currently looking into the 280yz, but anyone heard of the bob sharp kit? fiberglass doors and all that? i am planning a full cage in the car, so im not worried about running flimsy doors Lloyd
there was one guy on here a couple years ago who built a dash out of 2 or 3 pieces of aluminum and bolted it all together, with the top piece being removable so you could access the wires and such. it turned out pretty wicked and it was my inspiration for the dash i am building. no pictures of mine, cause HEY, i have no money but anyways, i think there are pictures floating around somewhere around here. love the pic above though, SUPER simple and clean, LOVE IT Lloyd
you can have a surge tank and fuel cell mounted inside of the hatch, but the fuel lines cannot run through the cabin, and if you have fuel system inside the hatch, a rear bulkhead must be used. accord to scca/nasa/formula-d/d1 rules ie: note that this system is in the trunk of an s14, with a firewall instead of back seats. Lloyd
if it were me, and its what im going to do to my rb when i get around to it, is tear it apart, and replace all of the bearings, piston rings, gaskets, upgrade the oil pump, water pump, head gasket, just rebuild the whole thing. i dont think it would be that much, seeing as you wouldent have to buy any of the expensive stuff, cams, valves, crank, just rebuild and get going. but thats just me. i have never bought an engine from an import service and not torn it apart. half of the time, with rotaries at least, they are either blown or have underlying issues that will rear their ugly heads right after the 30 days is up. Lloyd
roye, im in norcal, about 750 miles from san diego lol. ive done the drive a few times. i know, WE NEED PICTURES. im thinking about building an oven out of scrap steel that my friend has laying around then going to an e-waste place and getting a few elements and some nice controls. Lloyd
i got a question for you powder coaters. i need to get a bigger oven, but i cant find one big enough to cook a straight 6 valve cover. i have thuoght about doing the pregnant oven trick, but did you guys have any other suggestions, or plans for a home made oven. Lloyd
its just powder. you can powdercoat anything that will hold a charge, and what i did was attach the electrode to the engine pieces themselves, so the powder static clings to the piece. you can do 10 layers of powder and if you have a decent gun it will still adhere to the piece. Lloyd
ive seen them done, but i guess you would have to be careful with how long you bake them. and i dont think warpage would matter much, seeing as when the trim is clipped on, they wont be warped. idk, someone on here did them. Lloyd
heres what the housings looked like step by step: right after tear down: after sandblasting chrome powder applied before baking after first coat with chrome and ready for the candy blue candy blue before baking candy blue out of the oven and heres the back of the rear iron in the black, it looked wet, but wasnt, i love that powder. i am doing the whole VW engine that color. skeet skeet so, like i said, the outgassing was there, but not barely noticeable. i used the sand blasting cabinent before, followed with 2 days soaking in chemdip to get rid of all the shavings and oil and crap. then used simple green to reprep the pieces, a bit of a wire wheel, then the rest was all powdering. all in all, about 40 hours of work between the porting and coating Lloyd
you know, i havent had too much of a problem with outgassing. i dont cook the parts too long, i found out that if you preheat the parts enough before hand and get them up to just above being able to handle them by hand, the outgassing isnt nearly as bad as before. i will take pictures of the vw engine i am currently doing. i didnt preheat this: as you can tell, there is outgassing. it was covered up by the candy blue, then the whole front cover was replaced and redone, wasnt up to my standards. like i said, i will take pictures of the vw engine i am doing. i preheated them and there was no outgassing, everything came out glassy smooth. Lloyd p.s. i have heard that using iron phosphate to prep parts helps make the piece come out nicer and smoother. either the phosphate helps smooth the surface and cut down on the amount of micro air pockets, or just makes the area clean and ready for powder, idk. i dont use iron phosphate, i use my old bosses sand blasting cabinent. its a mix of medium grit sand and #6 glass bead.
i just pickedup myself the kool koat 3.0 gun from columbiacoatings.com........such a badass gun. i have been messing around with the hyper mirror black and candy colors. heres a rotary i did using the black and chrome and candy blue i redid the front cover, i did it with my craftsman gun, i hated that thing ported the engine as well. its from a 93 usdm rx7. 13brew is its classification Lloyd
i have no idea. rx7 drift car, fc to be exact Lloyd
of course dry ice. i used that when stripping out my 7 to make it my drift car. its a well known process and they started doing cryo-blasting too. they use dry ice in place of a media, its a beautiful thing. look it up on youtube or something. Lloyd
there is a cryoblaster up in santa rosa. ive been looking into it only because my Z is super clean minus like 3 spots and the floor boards. ive only looked into it because it wont hurt anything while being blasted, no friction=no heat=no warpage=awsomeness. Lloyd
it IS a larger engine, but internally. as far as the exterior size is concerned, same size. direct bolt in, promise. Lloyd
the old 911 engines were direct bolt ins yes. there was a few big differences between them, like the oiling system and a bit higher hp, but besides that, almost same engine. Lloyd
ya, only when it comes to the rx7. as far as my hybridz, thats just another story. and my bug too, i would love to build some ridiculous vw. just for grins Lloyd
i dont know how long you have ran with the rotary, but i dont see you having any basis in having this oppinion. 1) i am deeply involved in the rotary lifestyle (rx7club.com-magus2222) 2) i have a friend a town south of me running 750hp 20b running 25lbs boost in the streets, 40lbs on the strip. NEVER had a problem with it, still stupid powerful (oh, and built the entire car for 20g, including the engine) 3) my s5 gtu ran 170k miles while being drifted, auto-x'ed, dd, high speed driving, the whole 9 yards, never had any problems til the oil control rings just failed. never leaked, no cracked irons, housings were still perfect. so, to say that the rotary is anything short than near perfection is ridiculous. besides, there really isnt many people out there with the balls to mess with them. i am one of the very few people that will build them to extremes and still almost guarentee power for 100k miles or more. so, unless you are one of these people, you really dont have a good basis for a negative oppinion of the rotary. i love the rotary, but the rb is a beautiful engine as well. im very excited to get my build going on my 280z. Lloyd p.s. of for the love of god, if you have a 10th AE, dont bastardize it with a piston engine. leave it alone or sell it, since you obviously cant appreciate the rare factor and bragging rights involved in owning a TRUE 10ae
Pulling a Spindle Pin
rbpowered280z replied to jtburf's topic in Brakes, Wheels, Suspension and Chassis
when i did mine, it took us having to take it to a shop to have it pressed out. 15 tons of pressure, after the guy heated it up a few times, and 1/2 a bottle of wd40. ridiculous. Lloyd -
240z adjustable ride height
rbpowered280z replied to aziza z's topic in Brakes, Wheels, Suspension and Chassis
i got all of this from modern-motorsport.com i have been running this kit on this control arm setup with the tokico illumina 5-way adjustable strut inserts. with the energy suspension bushings. only thing about the spring kit, is that you have to disassemble the strut tubes, clean them out, clean the tube, weld on the spring perch that they provide, then reassemble. its very straight forward. only reason i decided to change the control arm is that i wanted to be able to fully set the suspension geometry according to my taste. ill tell you what, replacing that damned spindle bolt is retarded. 15 tons of pressure on a press after heating it up, bought new spindle bolts from nissan for only like 15$ Lloyd
