Hybrid240z
Hybrid240z last won the day on June 22 2013
Hybrid240z had the most liked content!
About Hybrid240z
  • Birthday March 18
Contact Methods
  • AIM
    lt1240zmech
  • Gender
    Male
  • Location
    So Cal
Recent Profile Visitors
Hybrid240z's Achievements
Newbie
  1. I can tell you that John Coffey recommended not running urethane tension rod bushings, only rubber ones. I believe he said that urethane bushings limit the required movement of the tension rod and can damage the tension rod, which makes sense. I don't think running a rear urethane bushing would be as much of a problem if you run the T/C kit, but I would recommend rubber bushings. I installed rubber tension rod bushings in my Z.
  2. I see two reasons why an intercooler on a non-turbo engine will probably not improve hp and may actually hurt it. The reason intercoolers help make more hp on turbo engines is that the air going through the turbo gets heated by the turbo so there is a temperature differential between the charged air and the surrounding air cooling the intercooler. On a non-turbo engine there is little to no temperature differential so no hp gain. The second problem is that the IC and tubing are essentially flow restrictors. This is overcome in a turbo application but not in a non-turbo application.
  3. Right, VG30 swap with a single turbo I believe.
  4. That 240Z is owned by Craig. He is the owner of SimTec Motorsports in Valencia, CA. Here is his shop's site: http://simtecmotorsports.com/ The black and white 300ZX on the website is also his. I believe he is building a similar sheetmetal airdam and splitter on his 240Z as is on his 300ZX. His contact info is on his site.
  5. Mike, Is that gas coming out of the fill tube/gas cap in the photo?
  6. The red 240z in the build competition looked decent. This white one looks horrible. They should have crushed this one.
  7. Great deal on the tail lights and hatch. I saw your last vid, the sound coming out of the RB30/25turbo is awesome. It looks like it is pulling harder than the L28turbo ever did, even after you fixed the spark plug problem. Do you have plans to dyno it soon?
  8. I don't know if you've seen Piston's thread of his 2JZ-GE turbo S30. Nice Z and setup. Very tempting to do on my z if I ever redo my drivetrain. http://forums.hybridz.org/topic/109694-vid-of-my-2jz-s30z-with-the-gopro2/
  9. I'm looking for a Treadstone TRV185 or similar with the inlet and outlet on the same side, BOV Super Sound or a similar known brand BOV (don't want a cheap knockoff), 2.5 inch aluminum piping, red silicone hoses, and clamps. Budget is limited right now so i'm trying to find what I need at a discount before buying new. Send me a PM with what you have for sale. Thanks.
  10. I bought a used L31ET with an F54 block. They sonic tested five F54 blocks until they finally found one that they were happy with. Crossing Fingers...haven't ran it yet but has even compression. It sounds like it would be a good idea to have any block that you are planning to use sonic tested.
  11. I was watching the auction with like 20 minutes to go and it was somewhere between 32k-36k from what I remember. Then all of sudden it was at the $200 bid and the auction had ended.
  12. Thanks for the info guys. JSM, I did see that info on the manual but that number is for the non-heated sensor. I'm planning on using a heated sensor. I did notice on the electromotive forum that you can run the analog output from the AEM wideband to the tec2 using a small circuit. I'm going to give that a try.
  13. Great to hear that your Z is no longer for sale. Awesome build.
  14. Miles is right about the unbalanced issue when running the Toyo front setup you mentioned together with the 240SX rear setup. I have read there may be the same issue when running the 280ZX rear setup too. From info posted so far, the Silvermine stage 4 rear kit is the one to run with the Toyo front setup to end up with a brake system that can be balanced using an adjustable proportioning valve.
  15. Can't find a replacement for the Bosch 48617B0 universal oxygen sensor that came with my tec2. The new universal Bosch numbers are different. The old sensor was manufactured in 2002. What is the correct Bosch sensor to use on the tec2? The auto parts store guy said it may be the 15730. Thanks.
